We have designed our custom board referring Jetson AGX Orin devkit and design guide and need to configure the UPHY in configuration #2 to make the PCIe interfaces to work. see our required interface mapping in below picture.
Can you please let me know if this is correct or anything went wrong or missing?
Also do I need to make any change in the source or SOC or pinmux for this?
Oh Ok, so this change is correct?
ODMDATA=“gbe-uphy-config-0,hsstp-lane-map-3,hsio-uphy-config-16,nvhs-uphy-config-0”;
How to know if it is config#2?
on what basis this is named? I could not get the index config-0,map-3, config-16 here. referred the Configuring the UPHY Lane in board bring up guide but could not figure it out.
Your hardware guy who designed this board would know. If they don’t even know, then please check the Orin AGX product design guide…
Config #2 has nothing to do with those numbers which you don’t understand.
Try to share the UART log during boot… We are not all-knowing person. I don’t know you and your board. Not able to tell what is missing by just few words here.
