hi ,
i m facing issues with USB PCIE card with new jetson orin kit that i dont see issues with agx xavier.
i went through 2 issues in forums
Please share the full log.
I’m trying to use a PCIe card with the AGX Orin Developer Kit.
The problem is that the 3.3V and 12V power supplies are not enabled after inserting a card. Only the 3V3AUX supply is active.
Now, I was able to enable the power supplies by updating the device tree file tegra234-p3737-fixed-regulator.dtsi as follows:
remove the flag “regulator-boot-on” for the nodes p3737_vdd_3v3_pcie and p3737_vdd_12v_pcie
p3737_vdd_3v3_pcie: change the gpio pin value to TEGRA234_MAIN_GPIO(H, 4)
Is …
i m bit confused how to follow that process to relfash the board.
please provide me detailed steps to reflash i require to flash the image
@vandev @WayneWWW
What is the exact interface? You said USB PCIe card, so is it pcie or usb?
its PCIe card not working,
please guide me steps to reflash the board with the fix so that i can use PCIe card on new jetson orin.
i m not able to understand the fix in this below link
@ralf.goebel ralf.goebel please help me how you fixed the issue with detailed steps please
Is …
Is your pcie card connecting on the x16 port of the devkit?
Also, is your board a NV devkit? The patch from the link you posted can only applied to devkit and “specific dekivt”. Not all sku of devkit can work with that.
hi @WayneWWW ,
yes, im connecting PCIe card to jetson orin kit. im facing same issue that faced in below posted link
Is …
i require your help on reflash the jetpack 5.1 DP image on orin with above software patch suggested in above link ..
how can i update the device tree file tegra234-p3737-fixed-regulator.dtsi "??
@kayccc @WayneWWW @Trumany please help to fix this issue, thanks
There is no official solution yet and that patch may not fix your problem either. Will update the solution later.
You can learn how to build kernel first.
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SD/Kernel.html
This is my working version of the device tree file:
tegra234-p3737-fixed-regulator.dtsi (5.7 KB)
It can be found in the source directory hardware\nvidia\platform\t23x\concord\kernel-dts\cvb.
Here is the generated dtb file:
tegra234-p3701-0000-p3737-0000.dtb (300.2 KB)
The file can be copied to /boot/dtb/ on the dev-kit. The configuration file /boot/extlinux/extlinux.conf should be modified to use the dtb file (FDT entry). I think the original dtb file is named differently (kernel_tegra234…dtb). I created a new menu entry so I can switch between different versions by using the debug UART on the micro-USB connector.
Ralf
