I’m trying to use a PCIe card with the AGX Orin Developer Kit.
The problem is that the 3.3V and 12V power supplies are not enabled after inserting a card. Only the 3V3AUX supply is active.
Now, I was able to enable the power supplies by updating the device tree file tegra234-p3737-fixed-regulator.dtsi as follows:
remove the flag “regulator-boot-on” for the nodes p3737_vdd_3v3_pcie and p3737_vdd_12v_pcie
p3737_vdd_3v3_pcie: change the gpio pin value to TEGRA234_MAIN_GPIO(H, 4)
Hi, have you checked the pin PRSNT2 status when PCIe device plug in? It should be changed when device plug in, otherwise module can’t get the note and then enable power supply.
