Is it possible to encode h264 by slice with NvVideoEncoder? It has methods to set the slice length and slice intra-refresh, and while those methods report success, the NALs the encoder generates don’t respect any slice length limit.
We support slice length in macroblocks and bytes:
-slt <type> Slice length type (1 = Number of MBs, 2 = Bytes) [Default = 1]
-slen <length> Slice length [Default = 0]
Do you run your case in macroblocks or bytes?
Hi DaneLLL, I’ve tried with both, and in neither case does the NAL length change. I’m using libargus, calling setSliceLength in NvVideoEncoder, so I’d expect the v4l2_buffer in the encoder callback to be smaller than the slice size I set, but that’s not the case. I’ve tried a variety of slice sizes, and I’m setting it after the format is set, per the comments in the NvVideoEncoder header.
Please refer to
[url]https://devtalk.nvidia.com/default/topic/1035839/jetson-tx2/how-does-slice-mode-video-encoding-work-for-jetson-/post/5267080/#5267080[/url]
The frame can be encoded into multiple slices, but it is sent out in a complete frame.
Hi @DaneLLL, based on your answer, I was expecting to find multiple NALs corresponding to individual slices in the encoder buffer in the dequeue thread, but that’s not the case. My goal is to slice the encoder output so that it is more resilient in the face of packet loss, and the way to do that is to make each slice smaller than the MTU of my radio. Is this impossible in Argus?
Encoding by slice doesn’t seem particularly useful if the resulting slices are all piled into a single NAL.
Please refer to following commands:
01_video_encode$ gst-launch-1.0 nvcamerasrc num-buffers=10 ! nvvidconv ! video/x-raw,width=640,height=480 ! filesink location= a.yuv
01_video_encode$ ./video_encode a.yuv 640 480 H264 a.h264 -slt 1 -slen 300
And JM decoder output(partial):
Annex B NALU w/ long startcode, len 1452, forbidden_bit 0, nal_reference_idc 3, nal_unit_type 1
@454 SH: first_mb_in_slice 1 ( 0)
@455 SH: slice_type 1 ( 0)
@456 SH: pic_parameter_set_id 1 ( 0)
@457 SH: frame_num 00000010 ( 2)
@465 SH: pic_order_cnt_lsb 00000100 ( 4)
@473 SH: num_ref_idx_override_flag 0 ( 0)
@474 SH: ref_pic_list_reordering_flag_l0 0 ( 0)
@475 SH: adaptive_ref_pic_buffering_flag 0 ( 0)
@476 SH: slice_qp_delta 00111 ( -3)
@481 SH: disable_deblocking_filter_idc 1 ( 0)
@482 SH: slice_alpha_c0_offset_div2 1 ( 0)
@483 SH: slice_beta_offset_div2 1 ( 0)
decode_one_slice POC: 2 Type 0
Annex B NALU w/ short startcode, len 1734, forbidden_bit 0, nal_reference_idc 3, nal_unit_type 1
@484 SH: first_mb_in_slice 00000000100101101 (300)
@501 SH: slice_type 1 ( 0)
@502 SH: pic_parameter_set_id 1 ( 0)
@503 SH: frame_num 00000010 ( 2)
@511 SH: pic_order_cnt_lsb 00000100 ( 4)
@519 SH: num_ref_idx_override_flag 0 ( 0)
@520 SH: ref_pic_list_reordering_flag_l0 0 ( 0)
@521 SH: adaptive_ref_pic_buffering_flag 0 ( 0)
@522 SH: slice_qp_delta 0001101 ( -6)
@529 SH: disable_deblocking_filter_idc 1 ( 0)
@530 SH: slice_alpha_c0_offset_div2 1 ( 0)
@531 SH: slice_beta_offset_div2 1 ( 0)
Annex B NALU w/ short startcode, len 1930, forbidden_bit 0, nal_reference_idc 3, nal_unit_type 1
@532 SH: first_mb_in_slice 0000000001001011001 (600)
@551 SH: slice_type 1 ( 0)
@552 SH: pic_parameter_set_id 1 ( 0)
@553 SH: frame_num 00000010 ( 2)
@561 SH: pic_order_cnt_lsb 00000100 ( 4)
@569 SH: num_ref_idx_override_flag 0 ( 0)
@570 SH: ref_pic_list_reordering_flag_l0 0 ( 0)
@571 SH: adaptive_ref_pic_buffering_flag 0 ( 0)
@572 SH: slice_qp_delta 00111 ( -3)
@577 SH: disable_deblocking_filter_idc 1 ( 0)
@578 SH: slice_alpha_c0_offset_div2 1 ( 0)
@579 SH: slice_beta_offset_div2 1 ( 0)
Annex B NALU w/ short startcode, len 2732, forbidden_bit 0, nal_reference_idc 3, nal_unit_type 1
@580 SH: first_mb_in_slice 0000000001110000101 (900)
@599 SH: slice_type 1 ( 0)
@600 SH: pic_parameter_set_id 1 ( 0)
@601 SH: frame_num 00000010 ( 2)
@609 SH: pic_order_cnt_lsb 00000100 ( 4)
@617 SH: num_ref_idx_override_flag 0 ( 0)
@618 SH: ref_pic_list_reordering_flag_l0 0 ( 0)
@619 SH: adaptive_ref_pic_buffering_flag 0 ( 0)
@620 SH: slice_qp_delta 0001001 ( -4)
@627 SH: disable_deblocking_filter_idc 1 ( 0)
@628 SH: slice_alpha_c0_offset_div2 1 ( 0)
@629 SH: slice_beta_offset_div2 1 ( 0)
Each NAL contains 300 macroblocks.
Thanks! I was looking for long NAL start codes (00 00 00 01), but only the first slice starts with the long start code–subsequent slices start with 00 00 01.
