Encoder multi media api memory leak
Hi
I run on Tx2 using l4t 32.7.3
I run encode mm api application h264 from i420 raw file run with parameter -s 1000 so will run1000 times.
Over time I can see there is memory leak
Can you help me?
This is duplicate of
Encoder memory leak
We will need some time to set up developer kit and check. Will update once there is further finding.
