Encoder.set_property("bitrate", 2000000) AttributeError: 'NoneType' object has no attribute 'set_property'
• Hardware Platform (Jetson / GPU)-jetson agx xavier
• DeepStream Version-6.1
• JetPack Version (valid for Jetson only)-
• TensorRT Version -8.4.1
I am trying to run the sample deepstream-opticalflow app using python. when I run the command
python3 deepstream-opticalflow.py file:///opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_720p.mp4
I have the following error.
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating tiler
Creating nv optical flow element
Creating nv optical flow visualisation element
Creating queue
Creating queue
Creating Queue
Creating nvosd
Creating converter 2
Creating capsfilter
Creating Encoder
Unable to create encoder
File “deepstream-opticalflow.py”, line 377, in
sys.exit(main(sys.argv))
File “deepstream-opticalflow.py”, line 288, in main
encoder.set_property(“bitrate”, 2000000)
AttributeError: ‘NoneType’ object has no attribute ‘set_property’
How do I resolve this error.
It seems to be a problem with your environment.
First, you can install deepstream step by step by referring to the link below:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html#jetson-setup
Second, you should install the python binding step by step by referring to the link below:
https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/bindings
Please make sure the version of DeepStream when you install it.
Hi, I have successfully installed deepstream and python bindings. I can run the other test apps successfully. This problem comes only when I run deepstream-opticalflow app.
It seems that some plugins are not installed. You can try to install dependent plugins with the command below:
apt-get install -y gstreamer1.0-libav
apt-get install --reinstall -y gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly libavresample-dev libavresample4 libavutil-dev libavutil56 libavcodec-dev libavcodec58 libavformat-dev libavformat58 libavfilter7 libde265-dev libde265-0 libx264-155 libx265-179 libvpx6 libmpeg2encpp-2.1-0 libmpeg2-4 libmpg123-0
