AttributeError: 'NoneType' object has no attribute 'set_property' deepstream 6.2
• Hardware Platform (Jetson / GPU) Jetson AGX Orin
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1
• TensorRT Version 8.5.2.2
• Issue Type( questions, new requirements, bugs) bugs
I have installed deepstream 6.2 and python apps along with the python bindings deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub . However when running the first test sample i get the below error
python3 deepstream_test_1.py opt/nvidia/deepstream/deepstream-6.2/samples/streams/sample_720p.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Unable to create NvStreamMux
Unable to create pgie
Creating nv3dsink
Playing file file:///opt/nvidia/deepstream/deepstream-6.2/samples/streams/sample_720p.h264
File “deepstream_test_1.py”, line 258, in
sys.exit(main(sys.argv))
File “deepstream_test_1.py”, line 196, in main
streammux.set_property(‘width’, 1920)
AttributeError: ‘NoneType’ object has no attribute ‘set_property’
I have tried the installation with & without virtual envs but i’m still facing the same issue.
Is this topic duplicate to 257449
Please check the suggestion shared in the above topic.
