對. 所以你的host PC可以讀到Jetson EP in lspci. 但後續的driver for tegra_pcie_dma_epf是沒有支援的. 請自行針對x86 host撰寫driver.
Related topics
将jetson orin nano 配置为 endppoint 执行 cat /sys/kernel/debug/14160000.pcie-ep_epf_dma_test/edmalib_test 报错 RP DMA address is null | 12 | 101 | December 4, 2024 | |
NVIDIA Jetson ORIN Dev as a EP failed to detect on x86 machine | 9 | 351 | May 15, 2024 | |
Enable Jetson Orin NX PCIe Endpoint for C4 | 4 | 79 | October 31, 2024 | |
How to configure pcie endpoint mode on jetson orin nx | 20 | 254 | February 9, 2025 | |
PCIe endpoint dma driver usage example | 4 | 368 | June 11, 2024 | |
PCIE test probelem | 10 | 728 | January 22, 2025 | |
PCIe ep Test Fail on AGX orin:RP DMA address is null .Version:R36.3 | 14 | 115 | November 21, 2024 | |
PCIe C4 endpoint mode on Orin NX | 12 | 91 | October 18, 2024 | |
Does Orin NX Endpoint mode support pcie hot-plugin? | 15 | 416 | August 12, 2024 | |
Configuring C5 controller as PCIe EP | 6 | 474 | June 6, 2024 |
