I’m using Orin NX Endpoint mode and work fine.
In our case, we connect the x86 host to Orin NX EP to be a system.
The host can detect the EP mode Orin NX and get the data.
We know the normal case is the Orin NX set to EP mode before the Host device boot up.
But in our case, the x86 host and Orin NX are in the all-in-1 system machine. The x86 host will boot up before Orin NX.
The x86 host will not detect the Orin NX because it is not the EP mode.
We want : x86 host boot up → Orin NX boot and set to EP mode → x86 host rescan and detect Orin NX.
But the x86 host can’t detect the Orin NX if the x86 host boot up before the Orin NX.
We try rescan the pcie but still can’t detect the Orin NX.
We test the M.2 PCIE SSD. It can be detected after x86 host boot up and rescan pcie.
Does Orin NX Endpoint mode support pcie hot-plugin?
我們正在使用x86 host和Orin NX EP接在一起作為一整個系統。
x86 host 可以正常抓到EP mode Orin NX並正常取得資料。
Hi, Orin IOs should not be powered on after host as that will affect the pin status of Orin. If you have to do that, the below isolation circuitry is required on the PCIe control signals when Orin module is configured as Endpoint.
