ivder
April 24, 2019, 6:23am
#1
Hi I’m using Jetson TX2 with the newest Jetpack 4.2, and I want to test my onboard camera, because I also failed to open my GoPro Camera on Tx2. With this command :
gst-launch-1.0 nvcamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12' ! nvoverlaysink -ev
I got following error
WARNING: erroneous pipeline: no element "nvcamerasrc"
Any solution?
nvcamerasrc is deprecated. Use nvarguscamerasrc instead.
Please check if GoPro Hero 5 is a valid USB camera first:
https://devtalk.nvidia.com/default/topic/1050691/jetson-tx2/gopro-camera-not-working-in-jetson-tx2/post/5332502/#5332502
Not sure if GoPro is a good USB camera, but obviously it is not a Bayer camera, hence cannot run nvarguscamerasrc.
ivder
April 24, 2019, 7:07am
#4
@Honey_Patouceul Thanks it works. 1 question, after enter that command it will enter full screen, and I couldn’t exit the full screen mode except by resetting the board. Any tips?
You may maximize the terminal where you launch the pipeline. Don’t click mouse that could change the focused window, so typing Ctrl-C will be catched by the terminal and close the pipeline.
Alternately, you can use xvimagesink display if you are running the GUI:
gst-launch-1.0 nvcamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12' ! nvvidconv ! xvimagesink
ivder
April 24, 2019, 7:58am
#6
@Honey_Patouceul Thanks! Works like charm. Now I only need to figure out how to open my GoPro camera
If your GoPro camera is plugged in and has video node /dev/video1, what gives:
v4l2-ctl -d /dev/video1 --list-formats-ext
(v4l2-ctl is provided by package v4l-utils, you can install it with apt).
ivder
April 24, 2019, 8:12am
#8
@Honey_Patouceul it gives :
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.017s (59.940 fps)
Interval: Discrete 0.020s (50.000 fps)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.033s (29.970 fps)
Interval: Discrete 0.040s (25.000 fps)
Size: Discrete 1280x1024
Size: Discrete 1600x1200
Size: Discrete 1680x1050
Size: Discrete 1920x1080
Size: Discrete 1920x1200
I already made separate topic for that, but still no luck https://devtalk.nvidia.com/default/topic/1050691/jetson-tx2/gopro-camera-not-working-in-jetson-tx2/post/5332502/#5332502
