Running Ubuntu 10.10 with automatically installed nvidia-current driver, version 260.19.06.
Installed CUDA Toolkit for Ubuntu Linux 10.04 64 bit from CUDA Toolkit 3.2 Downloads | NVIDIA Developer
http://www.nvidia.com/object/thankyou.html?url=/compute/cuda/3_2_prod/toolkit/cudatoolkit_3.2.16_linux_64_ubuntu10.04.run
Installed “GPU Computing SDK code samples and more” from Open Computing Language OpenCL | NVIDIA Developer http://developer.download.nvidia.com/compute/cuda/2_3/opencl/sdk/gpucomputingsdk_2.3a_linux.run into default directory ~/NVIDIA_GPU_Computing_SDK
Built CUDA stuff via “cd ~/NVIDIA_GPU_Computing_SDK/C/ ; make”. Got 6 files in /NVIDIA_GPU_Computing_SDK/C/bin/linux/release, all run, and generally say things like “TEST PASSED”.
Built OpenCL examples via “~/NVIDIA_GPU_Computing_SDK/OpenCL/ ; make”. No errors. Everything in ~/NVIDIA_GPU_Computing_SDK/OpenCL/bin/linux/release says something including “!!! Errror # -32 at line…”
$ ./oclTranspose
./oclTranspose Starting…
!!! Error # -32 at line 70 , in file oclTranspose.cpp !!!
Exiting…
$ ./oclBlackScholes
./oclBlackScholes Starting…
Allocating and initializing host memory…
Initializing OpenCL…
!!! Error # -32 at line 112 , in file Source/oclBlackScholes.cpp !!!
Exiting…
$ ./oclConvolutionSeparable
./oclConvolutionSeparable Starting…
!!! Error # -32 at line 53 , in file src/main.cpp !!!
Exiting…
$ head -n 70 ./src/oclTranspose/oclTranspose.cpp | tail -n 1
shrCheckError(ciErrNum, CL_SUCCESS);
$ head -n 112 ./src/oclBlackScholes/Source/oclBlackScholes.cpp | tail -n 1
$ head -n 53 ./src/oclConvolutionSeparable/src/main.cpp | tail -n 1
Hey look, a pattern.
Any idea what the problem is?
Using Device 0: “GeForce 9300 GE”
$ lspci | grep -i vga
01:00.0 VGA compatible controller: nVidia Corporation G98 [GeForce 9300 GE] (rev a1)
Somebody else was able to get OpenCL working on Ubuntu 10.10: The Official NVIDIA Forums | NVIDIA
“Error code -32 means CL_INVALID_PLATFORM, so I think you can run oclDeviceQuery sample to check if you are working on a valid platform.”
“You’re passing null in for the platform. You now have to pass in a valid platform object to create a context.”
$ ./oclDeviceQuery
OpenCL Device Info:
There are no devices supporting OpenCL (return code -32)
GeForce 9300 mGPU, GeForce 9300M GS, GeForce 9300M G are listed as supported. Is my 9300 GE really not supported?
