My main intent here is to build and boot the tiniest kernel to see what the fastest boot time available is.
I’m encountering an error when attempting to build the kernel using make vmlinux
on a Nano 35.4.1 setup, within the Linux_for_Tegra/source/public/kernel/kernel-5.10 directory. The error persists even when I try using make tinyconfig
as a preliminary step. Below are the error messages for both commands:
For make vmlinux
make vmlinux
SYNC include/config/auto.conf.cmd
GEN Makefile
make[3]: *** [/home/tonbo/vc_mipi_nvidia/build/Nano_35.4.1/Linux_for_Tegra/source/public/kernel/kernel-5.10/scripts/kconfig/Makefile:71: syncconfig] Error 1
make[2]: *** [/home/tonbo/vc_mipi_nvidia/build/Nano_35.4.1/Linux_for_Tegra/source/public/kernel/kernel-5.10/Makefile:633: syncconfig] Error 2
make[1]: *** [/home/tonbo/vc_mipi_nvidia/build/Nano_35.4.1/Linux_for_Tegra/source/public/kernel/kernel-5.10/Makefile:742: include/config/auto.conf.cmd] Error 2
make: *** [/home/tonbo/vc_mipi_nvidia/build/Nano_35.4.1/Linux_for_Tegra/source/public/kerne
And with make tinyconfig
, I encounter a similar failure.
make[5]: *** [/home/tonbo/vc_mipi_nvidia/build/Nano_35.4.1/Linux_for_Tegra/source/public/kernel/kernel-5.10/scripts/kconfig/Makefile:71: allnoconfig] Error 1
make[4]: *** [/home/tonbo/vc_mipi_nvidia/build/Nano_35.4.1/Linux_for_Tegra/source/public/kernel/kernel-5.10/Makefile:633: allnoconfig] Error 2
make[3]: *** [/home/tonbo/vc_mipi_nvidia/build/Nano_35.4.1/Linux_for_Tegra/source/public/kernel/kernel-5.10/Makefile:365: __build_one_by_one] Error 2
make[2]: *** [/home/tonbo/vc_mipi_nvidia/build/Nano_35.4.1/Linux_for_Tegra/source/public/kernel/kernel-5.10/scripts/kconfig/Makefile:113: tinyconfig] Error 2
make[1]: *** [/home/tonbo/vc_mipi_nvidia/build/Nano_35.4.1/Linux_for_Tegra/source/public/kernel/kernel-5.10/Makefile:633: tinyconfig] Error 2
make: *** [/home/tonbo/vc_mipi_nvidia/build/Nano_35.4.1/Linux_for_Tegra/source/public/kernel/kernel-5.10/Makefile:213: __sub-make] Error 2
I’ve followed the standard kernel build process and haven’t made any modifications that should affect the build like this. Could someone suggest potential causes or solutions for these errors? Specifically, I’m looking for insights into resolving the syncconfig
error and whether there might be any dependency or environment configuration I’m overlooking.
The normal pipeline of make for modules, dev-tree, module_install, Image works fine.
Thank you in advance for any assistance or guidance.
