I’m having troubles compiling a single kernel module. I wrote a script to run these commands:
make O=~/build-dir LOCALVERSION="-tegra" tegra_defconfig
make O=~/build-dir LOCALVERSION="-tegra" menuconfig
# set device driver (TC358743) as a module (=m), I run the following command:
make O=~/build-dir LOCALVERSION="-tegra" modules_prepare
cp /usr/src/linux-headers-4.9.201-tegra-ubuntu18.04_aarch64/kernel-4.9/Module.symvers /home/bsg/build-dir/Module.symvers
make O=~/build-dir LOCALVERSION="-tegra" -j4 --output-sync=target M=drivers/media/i2c modules
Output error:
make[1]: Entering directory '/home/bsg/build-dir'
arch/arm64/Makefile:49: LSE atomics not supported by binutils
make[1]: Leaving directory '/home/bsg/build-dir'
LD drivers/media/i2c/soc_camera/built-in.o
CC drivers/media/i2c/imx477.o
CC drivers/media/i2c/imx219.o
CC drivers/media/i2c/imx318.o
CC drivers/media/i2c/imx268.o
CC drivers/media/i2c/lc898212.o
/home/bsg/kernel/source/public/kernel/nvidia/drivers/media/i2c/lc898212.c: In function ‘lc898212_init’:
/home/bsg/kernel/source/public/kernel/nvidia/drivers/media/i2c/lc898212.c:398:56: error: pointer targets in passing argument 3 of ‘regmap_read’ differ in signedness [-Werror=pointer-sign]
err |= regmap_read(priv->regmap16, LC898212_ADOFFSET, &data);
In file included from /home/bsg/kernel/source/public/kernel/nvidia/drivers/media/i2c/lc898212.c:25:0:
/home/bsg/kernel/source/public/kernel/kernel-4.9/include/linux/regmap.h:763:5: note: expected ‘unsigned int *’ but argument is of type ‘int *’
int regmap_read(struct regmap *map, unsigned int reg, unsigned int *val);
cc1: all warnings being treated as errors
/home/bsg/kernel/source/public/kernel/kernel-4.9/scripts/Makefile.build:335: recipe for target 'drivers/media/i2c/lc898212.o' failed
make[2]: *** [drivers/media/i2c/lc898212.o] Error 1
make[2]: *** Waiting for unfinished jobs....
CC drivers/media/i2c/ov9281.o
CC drivers/media/i2c/ov10823.o
CC drivers/media/i2c/ov23850.o
In file included from /home/bsg/kernel/source/public/kernel/kernel-4.9/include/linux/trace_seq.h:4:0,
from /home/bsg/kernel/source/public/kernel/kernel-4.9/include/linux/trace_events.h:6,
from /home/bsg/kernel/source/public/kernel/kernel-4.9/include/trace/trace_events.h:19,
from /home/bsg/kernel/source/public/kernel/kernel-4.9/include/trace/define_trace.h:95,
from /home/bsg/kernel/source/public/kernel/nvidia/include/trace/events/ov23850.h:45,
from /home/bsg/kernel/source/public/kernel/nvidia/drivers/media/i2c/ov23850.c:35:
/home/bsg/kernel/source/public/kernel/kernel-4.9/include/linux/seq_buf.h: In function ‘seq_buf_init’:
/home/bsg/kernel/source/public/kernel/kernel-4.9/include/linux/seq_buf.h:34:12: error: pointer targets in assignment differ in signedness [-Werror=pointer-sign]
s->buffer = buf;
/home/bsg/kernel/source/public/kernel/kernel-4.9/scripts/Makefile.build:335: recipe for target 'drivers/media/i2c/ov23850.o' failed
make[2]: *** [drivers/media/i2c/ov23850.o] Error 1
/home/bsg/kernel/source/public/kernel/kernel-4.9/Makefile:1646: recipe for target '_module_drivers/media/i2c' failed
make[1]: *** [_module_drivers/media/i2c] Error 2
Makefile:171: recipe for target 'sub-make' failed
make: *** [sub-make] Error 2
It looks like it’s successful in building some modules but then finds syntax errors in others. This is strange to me because with identical source files I can run:
make O=~/build-dir LOCALVERSION="-tegra" -j4 --output-sync=target modules
and then immediately run
and it builds/compiles all successfully.
What else do I need to add to my script to make this work? What else differs between the make modules and make M=directory?
Jamie
