Nvidia_kernel_display_driver_source compile error
related issue 1
related issue 2
my command:
export LOCALVERSION="-tegra"
export IGNORE_PREEMPT_RT_PRESENCE = 1
cd to NVIDIA-kernel-module-source-TempVersion
make \
    modules \
    SYSSRC=/home/fzy/Documents/02_智能网联/06_芯片/1_NVIDIA/01_Jetson_AGX_Orin_Series/jetson_linux_35_1/kernel/kernel/kernel-5.10 \
    SYSOUT=$(pwd)/extra_modules \
    CC=/home/fzy/opt/GCC_ARM/nvidia_orin_aarch64_gcc/bin/aarch64-buildroot-linux-gnu-gcc \
    LD=/home/fzy/opt/GCC_ARM/nvidia_orin_aarch64_gcc/bin/aarch64-buildroot-linux-gnu-ld.bfd \
    AR=/home/fzy/opt/GCC_ARM/nvidia_orin_aarch64_gcc/bin/aarch64-buildroot-linux-gnu-ar \
    CXX=/home/fzy/opt/GCC_ARM/nvidia_orin_aarch64_gcc/bin/aarch64-buildroot-linux-gnu-g++ \
    OBJCOPY=/home/fzy/opt/GCC_ARM/nvidia_orin_aarch64_gcc/bin/aarch64-buildroot-linux-gnu-objcopy \
    TARGET_ARCH=aarch64 \
    ARCH=arm64
error log:
make[1]: Leaving directory '/home/fzy/Documents/02_智能网联/06_芯片/1_NVIDIA/01_Jetson_AGX_Orin_Series/jetson_linux_35_1/display_driver/NVIDIA-kernel-module-source-TempVersion/src/nvidia-modeset'
cd kernel-open/nvidia-modeset/ && ln -sf ../../src/nvidia-modeset/_out/Linux_aarch64/nv-modeset-kernel.o nv-modeset-kernel.o_binary
make -C kernel-open modules
make[1]: Entering directory '/home/fzy/Documents/02_智能网联/06_芯片/1_NVIDIA/01_Jetson_AGX_Orin_Series/jetson_linux_35_1/display_driver/NVIDIA-kernel-module-source-TempVersion/kernel-open'
make[2]: Entering directory '/home/fzy/Documents/02_智能网联/06_芯片/1_NVIDIA/01_Jetson_AGX_Orin_Series/jetson_linux_35_1/kernel/kernel/kernel-5.10'
make[3]: Entering directory '/home/fzy/Documents/02_智能网联/06_芯片/1_NVIDIA/01_Jetson_AGX_Orin_Series/jetson_linux_35_1/display_driver/NVIDIA-kernel-module-source-TempVersion/extra_modules'
awk: fatal: cannot open file `include/generated/asm-offsets.h' for reading (No such file or directory)
scripts/Makefile.lib:8: 'always' is deprecated. Please use 'always-y' instead
The Module.symvers file is missing, or does not contain any
symbols exported from the kernel. This could cause the NVIDIA
kernel modules to be built against a configuration that does
not accurately reflect the actual target kernel.
The Module.symvers file check can be disabled by setting the
environment variable IGNORE_MISSING_MODULE_SYMVERS to 1.
make[4]: *** [/home/fzy/Documents/02_智能网联/06_芯片/1_NVIDIA/01_Jetson_AGX_Orin_Series/jetson_linux_35_1/display_driver/NVIDIA-kernel-module-source-TempVersion/kernel-open/Kbuild:229: module_symvers_sanity_check] Error 1
make[3]: *** [/home/fzy/Documents/02_智能网联/06_芯片/1_NVIDIA/01_Jetson_AGX_Orin_Series/jetson_linux_35_1/kernel/kernel/kernel-5.10/Makefile:1854: /home/fzy/Documents/02_智能网联/06_芯片/1_NVIDIA/01_Jetson_AGX_Orin_Series/jetson_linux_35_1/display_driver/NVIDIA-kernel-module-source-TempVersion/kernel-open] Error 2
make[3]: Leaving directory '/home/fzy/Documents/02_智能网联/06_芯片/1_NVIDIA/01_Jetson_AGX_Orin_Series/jetson_linux_35_1/display_driver/NVIDIA-kernel-module-source-TempVersion/extra_modules'
make[2]: *** [Makefile:213: __sub-make] Error 2
make[2]: Leaving directory '/home/fzy/Documents/02_智能网联/06_芯片/1_NVIDIA/01_Jetson_AGX_Orin_Series/jetson_linux_35_1/kernel/kernel/kernel-5.10'
make[1]: *** [Makefile:82: modules] Error 2
make[1]: Leaving directory '/home/fzy/Documents/02_智能网联/06_芯片/1_NVIDIA/01_Jetson_AGX_Orin_Series/jetson_linux_35_1/display_driver/NVIDIA-kernel-module-source-TempVersion/kernel-open'
make: *** [Makefile:50: modules] Error 2
Hi fzy438484102,
Please follow below steps and clean build again:
$ export ARCH=arm64
$ export LOCALVERSION="-tegra"
$ export CROSS_COMPILE=~/Toolchain_gcc_9.3/bin/aarch64-buildroot-linux-gnu-
$ cd NVIDIA-kernel-module-source-TempVersion/
$ make modules -j4 TARGET_ARCH=aarch64 SYSSRC=/home/carol/Desktop/Linux_for_Tegra/source/public/kernel/kernel-5.10 SYSOUT=/home/carol/Desktop/out-1020-RT CC=~/Desktop/CROSS_COMPILE/Toolchain_gcc_9.3/bin/aarch64-linux-gcc LD=~/Desktop/CROSS_COMPILE/Toolchain_gcc_9.3/bin/aarch64-linux-ld AR=~/Desktop/CROSS_COMPILE/Toolchain_gcc_9.3/bin/aarch64-linux-ar CXX=~/Desktop/CROSS_COMPILE/Toolchain_gcc_9.3/bin/aarch64-linux-g++ OBJCOPY=~/Desktop/CROSS_COMPILE/Toolchain_gcc_9.3/bin/aarch64-linux-objcopy
