CUDA Dev tools : 10.1
Mac : 10.13.6
web driver : 387.10.10.10.40.130
/usr/bin/cc --version
Apple LLVM version 10.0.0 (clang-1000.11.45.5)
Target: x86_64-apple-darwin17.7.0
Thread model: posix
InstalledDir: /Applications/Xcode_10.1.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin
I have successfully run this example :
make -C 0_Simple/vectorAdd
/Developer/NVIDIA/CUDA-10.1/bin/nvcc -ccbin clang++ -I../../common/inc -m64 -Xcompiler -arch -Xcompiler x86_64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_75,code=compute_75 -o vectorAdd.o -c vectorAdd.cu
/Developer/NVIDIA/CUDA-10.1/bin/nvcc -ccbin clang++ -m64 -Xcompiler -arch -Xcompiler x86_64 -Xlinker -rpath -Xlinker /Developer/NVIDIA/CUDA-10.1/lib -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_75,code=compute_75 -o vectorAdd vectorAdd.o
ld: warning: text-based stub file /System/Library/Frameworks//CoreFoundation.framework/CoreFoundation.tbd and library file
[u]/System/Library/Frameworks//CoreFoundation.framework/CoreFoundation are out of sync. Falling back to library file for linking.
mkdir -p ../../bin/x86_64/darwin/release[/u] -> ??
cp vectorAdd ../../bin/x86_64/darwin/release
any suggestion to solve this problem ?
regards
