I am using Digits from host to train Jetson, I get the following error while creating object detection model. I a following this article: GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson.
There was no detectnet.prototxt file. So I created one (pasted the code from: https://github.com/dusty-nv/jetson-inference/blob/master/data/networks/detectnet.prototxt )and dropped it into networks folder.
size-block does not need backward computation.
coverage-block does not need backward computation.
coverage-label_slice-label_4_split does not need backward computation.
obj-label_slice-label_3_split does not need backward computation.
size-label_slice-label_2_split does not need backward computation.
bbox-label_slice-label_1_split does not need backward computation.
foreground-label_slice-label_0_split does not need backward computation.
slice-label does not need backward computation.
val_transform does not need backward computation.
val_label does not need backward computation.
val_data does not need backward computation.
This network produces output loss_bbox
This network produces output loss_coverage
This network produces output mAP
This network produces output precision
This network produces output recall
Network initialization done.
Solver scaffolding done.
Finetuning from /home/brp/data/detectnet.prototxt
Check failed: fd != -1 (-1 vs. -1) File not found: /home/brp/data/detectnet.prototxt
Caffe log output is
I0301 10:06:32.426641 1039 net.cpp:222] slice-label does not need backward computation.
I0301 10:06:32.426645 1039 net.cpp:222] val_transform does not need backward computation.
I0301 10:06:32.426648 1039 net.cpp:222] val_label does not need backward computation.
I0301 10:06:32.426651 1039 net.cpp:222] val_data does not need backward computation.
I0301 10:06:32.426652 1039 net.cpp:264] This network produces output loss_bbox
I0301 10:06:32.426654 1039 net.cpp:264] This network produces output loss_coverage
I0301 10:06:32.426656 1039 net.cpp:264] This network produces output mAP
I0301 10:06:32.426659 1039 net.cpp:264] This network produces output precision
I0301 10:06:32.426664 1039 net.cpp:264] This network produces output recall
I0301 10:06:32.426782 1039 net.cpp:284] Network initialization done.
I0301 10:06:32.427223 1039 solver.cpp:60] Solver scaffolding done.
I0301 10:06:32.429873 1039 caffe.cpp:135] Finetuning from /home/brp/data/networks/detectnet.prototxt
F0301 10:06:32.429888 1039 io.cpp:54] Check failed: fd != -1 (-1 vs. -1) File not found: /home/brp/data/networks/detectnet.prototxt
*** Check failure stack trace: ***
@ 0x7fc3f123edaa (unknown)
@ 0x7fc3f123ece4 (unknown)
@ 0x7fc3f123e6e6 (unknown)
@ 0x7fc3f1241687 (unknown)
@ 0x7fc3f17ee62f caffe::ReadProtoFromBinaryFile()
@ 0x7fc3f17f5fb4 caffe::ReadNetParamsFromBinaryFileOrDie()
@ 0x7fc3f17c20b7 caffe::Net<>::CopyTrainedLayersFromBinaryProto()
@ 0x7fc3f17c2126 caffe::Net<>::CopyTrainedLayersFrom()
@ 0x40a604 CopyLayers()
@ 0x40ae25 train()
@ 0x4086bc main
@ 0x7fc3efd35f45 (unknown)
@ 0x408e8d (unknown)
@ (nil) (unknown)
Please help me . Thank you in advance
