• Hardware Platform (Jetson / GPU): Tesla T4 Gpu • DeepStream Version: 6.4 • TensorRT Version: * TensorRT 8.6.1.6 • NVIDIA GPU Driver Version (valid for GPU only): 535.104.12
I am using NVIDIA Tesla T4 GPU, what is the compatible torch version with it?When I do ‘nvidia-smi’ it showing correct output, but when i try to print GPU details with in a python script using ‘torch’ , it says
"UserWarning: CUDA initialization: CUDA driver initialization failed, you might not have a CUDA gpu. (Triggered internally at …/c10/cuda/CUDAFunctions.cpp:109.)
return torch._C._cuda_getDeviceCount() > 0
[2024-02-22 17:25:55,692: WARNING/ForkPoolWorker-2] CUDA is not available. Running on CPU."
i also have another machine with NVIDIA Tesla P100 ,what is the compatible torch version with it?
The compatibility of PyTorch with NVIDIA Tesla T4 and Tesla P100 GPUs depends on the CUDA version supported by the GPUs and the corresponding NVIDIA driver installed on your system. Both Tesla T4 and Tesla P100 GPUs are compatible with various versions of PyTorch, given that these GPUs support CUDA compute capability 6.0 and higher. The key is to match the PyTorch version with the CUDA version that is supported by your NVIDIA driver.
Alternatively, you can opt for the pre-existing Docker container available on NVIDIA NGC (PyTorch | NVIDIA NGC), allowing you to bypass the installation of the GPU driver and CUDA.
