GPU Driver Version for Telsa4
• Hardware Platform (Jetson / GPU) Telsa4
• DeepStream Version
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) ?
Hi, we want to install DS5.0 in T4, but we don not know which GPU Driver Version is suitable for T4.
Please refer to README:
DeepStream SDK
Setup pre-requisites:
  • Ubuntu 18.04
  • Gstreamer 1.14.1
    - NVIDIA driver 440+
  • CUDA 10.2
  • TensorRT 7.0+
Thanks for reply,I have tried NVIDIA driver 450.51,450.57 and 450.66,but didn’t work.
I install those drivers with the guide:
sudo ./NVIDIA-Linux-x86_64-450.51.run and set the environment variable INDIVIDUAL_DECODER_SCHEDULING to True.
I have the opengl,but when I run the test code in /opt/nvidia/deepstream/deepstream-5.0/sample/configs/deepstream
deepstream-app -c source4....txt
it caused libEGL warning: DRI2: failed to authenticate .I have solved this problem in another PC with 2080ti,by install the driver in cuda_10.2.89_440.33.01.linux.run.I found an available dirver in this runfile,when I replace the driver without any other operations,it works.
But when I try it on the T4,it doesn’t work.
I notice with sudo nvidia-xconfig --query-gpu-info ,the Number of display devices is 0,does it matters?
Because of T4 is not display card, it’s compute card.
But you can set sink type to File or RTSPStreaming for output viewing.
