Error found when re-compile the nvmsgconv
Jetson xaiver NX with Jetpack5.1.1 and deepstream-6.2.
I just want to re-compiler nvmsgconv plugin to provide new format message. I modify the code in the file: /opt/nvidia/deepstream/deepstream-6.2/sources/libs/nvmsgconv/deepstream_schema/dsmeta_payload.cpp.
Then I try to run the command: make && make install, but got the error as below:
It seems the compile command in Makefile is wrong?
Hope someone can help to clarify it, thanks in advance!
This is the syntax of Makefile, $< represents all dependencies.
Is deepstream_schema/schema.proto missing on your xaiver NX? You can copy the same file from x86
I did not find any proto files under deepstream_schema. Do you mean If I copy the file in the directory, then I can make without any modification in the Makefile?
By the way, I do not have file in x86. where can I get this file?
Yes, I can build it in Docker with DS-6.2 without any error.
  1. Download the tbz2 file, uncompress the tbz2 and copy proto file.
    GPU-optimized AI, Machine Learning, & HPC Software | NVIDIA NGC | NVIDIA NGC
2.Or Update to DS-6.3, This is the highest version xaiver can be upgraded to.
Thanks for your help. I have compiled the library file successfully.
