ERROR from element primary-nvinference-engine: Buffer conversion failed
jetpack 6.2
Tensorrt 10.3.0.30
cuda 12.6.68
cudnn 9.3.0.75
Driver Version: 540.4.0
• Hardware Platform (Jetson / GPU) Orin Nano Super Developer Kit
• DeepStream Version 7.1
• JetPack Version (valid for Jetson only) 6.2
• TensorRT Version 10.3.0.30
Normal object detection using YOLOV5 converted to ONNX using deepstream-yolo giving following error randomly and crashing on Orin Nano Super Developer Kit having deepstream 7.1. This is successfully running on Jetson Nano, dGPU A4000 since 3-4 years. When tested it on Orin Nano giving following errors.
[2025-02-13 17:14:57.402] [error] ERROR from element primary-nvinference-engine: Buffer conversion failed
[2025-02-13 17:14:57.402] [error] Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1576): gst_nvinfer_process_full_frame (): /GstPipeline:LogicMo-Queue-Buster/GstNvInfer:primary-nvinference-engine
[2025-02-13 17:14:57.402] [info] Returned, stopping playback
For DS-7.1, we have only tested it on Jetpack 6.1.
There may be some unknown issues with JP-6.2 on Orin nano super, Can you try to burn JP-6.1?
Will try to use JP-6.1 and revert. Thanks
