ERROR from src_elem: Internal data stream error while trying to connect USB camera to do detection
• DeepStream Version
hbrain@ubuntu:~/DeepStream-Yolo$ deepstream-app --version-all
deepstream-app version 6.3.0
DeepStreamSDK 6.3.0
CUDA Driver Version: 11.4
CUDA Runtime Version: 11.4
TensorRT Version: 8.5
cuDNN Version: 8.6
libNVWarp360 Version: 2.0.1d3
• JetPack Version (5.1.3)
• TensorRT Version
• Issue Type( ERROR from src_elem: Internal data stream error.)
** I am trying to do object detection using yolov8 in deepstream 6.3.0.
I have tested deepstream with recorded video, it worked but when I try to connect USB camera it is failed and saying
hbrain@ubuntu:~/DeepStream-Yolo$ deepstream-app -c deepstream_app_config_live_camera.txt
Opening in BLOCKING MODE
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
~~ CLOG[/dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvmultiobjecttracker/include/modules/NvMultiObjectTracker/NvTrackerParams.hpp, getConfigRoot() @line 52]: [NvTrackerParams::getConfigRoot()] !!![WARNING] Invalid low-level config file caused an exception, but will go ahead with the default config values
[NvMultiObjectTracker] Initialized
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:07.840309338 10261 0xaaaadd9a6960 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/home/hbrain/DeepStream-Yolo/model_b1_gpu0_fp16.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input 3x640x640
1 OUTPUT kFLOAT output 8400x6
0:00:07.926041146 10261 0xaaaadd9a6960 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 1]: Use deserialized engine model: /home/hbrain/DeepStream-Yolo/model_b1_gpu0_fp16.engine
0:00:07.941584096 10261 0xaaaadd9a6960 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/home/hbrain/DeepStream-Yolo/config_infer_primary_yoloV8.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
    p: Pause
    r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:239>: Pipeline ready
nvstreammux: Successfully handled EOS for source_id=0
** INFO: <bus_callback:225>: Pipeline running
Debug info: gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstV4l2Src:src_elem:
streaming stopped, reason not-negotiated (-4)
** INFO: <bus_callback:204>: incorrect camera parameters provided, please provide supported resolution and frame rate
** INFO: <bus_callback:262>: Received EOS. Exiting …
Quitting
[NvMultiObjectTracker] De-initialized
App run failed
Available camera is
hbrain@ubuntu:~/DeepStream-Yolo$ v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
/dev/media0
webcamproduct: usb-webcam (usb-3610000.xhci-2.1):
/dev/video0
/dev/video1
/dev/media1
i am using GitHub - marcoslucianops/DeepStream-Yolo: NVIDIA DeepStream SDK 8.0 / 7.1 / 7.0 / 6.4 / 6.3 / 6.2 / 6.1.1 / 6.1 / 6.0.1 / 6.0 / 5.1 implementation for YOLO models github repo.
my deepstream_app_config.txt file
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=1
rows=1
columns=1
width=1920
height=1080
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=1
camera-width=1920
camera-height=1080
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=0
gpu-id=0
[sink0]
enable=0 # Disabled for headless operation
[sink1]
enable=1
type=3
container=1
codec=1
bitrate=4000000 # Reduced bitrate for 720p
output-file=camera_720p_detections.mp4
source-id=0
sync=0
[osd]
enable=1
gpu-id=0
border-width=3
text-size=12
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
nvbuf-memory-type=0
display-bbox=1
display-text=1
process-mode=1
[streammux]
gpu-id=0
live-source=1
batch-size=1
batched-push-timeout=4000
Match camera resolution
width=1280
height=720
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV8.txt
interval=0
[tracker]
enable=1
Scale tracker resolution proportionally
tracker-width=640
tracker-height=360
gpu-id=0
ll-config-file=iou_config.txt
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
display-tracking-id=1
[tests]
file-loop=0
Refer to this FAQ first, use the gst-launch-1.0 command line tune v4l2src parameters, then modify the configuration file.
Thank you for you repsonse,
I have solved the issue by following the instruction on How to use deepstream-app with MJPEG format stream?
changed the cap1 value video/x-raw to image-jpeg
but it did not worked, and then modified the code to encoder jpeg video.
and then worked
