• Hardware :2080ti
• Network Type :LPRnet
• TLT Version :Configuration of the TLT Instance
dockers:
nvidia/tlt-streamanalytics:
docker_registry: nvcr.io
docker_tag: v3.0-py3
tasks:
1. augment
2. bpnet
3. classification
4. detectnet_v2
5. dssd
6. emotionnet
7. faster_rcnn
8. fpenet
9. gazenet
10. gesturenet
11. heartratenet
12. lprnet
13. mask_rcnn
14. multitask_classification
15. retinanet
16. ssd
17. unet
18. yolo_v3
19. yolo_v4
20. tlt-converter
nvidia/tlt-pytorch:
tasks:
1. speech_to_text
2. speech_to_text_citrinet
3. text_classification
4. question_answering
5. token_classification
6. intent_slot_classification
7. punctuation_and_capitalization
format_version: 1.0
tlt_version: 3.0
published_date: 04/16/2021
• Training spec file: https://raw.githubusercontent.com/NVIDIA-AI-IOT/deepstream_tlt_apps/release/tlt3.0/misc/dev_blog/LPDR/lpr/tutorial_spec.txt
• How to reproduce the issue ?
Just follow: Creating a Real-Time License Plate Detection and Recognition App | NVIDIA Technical Blog
All commands run successfully, until:
tlt lprnet train -e /workspace/tlt-experiments/lprnet/tutorial_spec.txt -r /workspace/tlt-experiments/lprnet/ -k nvidia_tlt -m /workspace/tlt-experiments/lprnet/us_lprnet_baseline18_trainable.tlt
2021-08-23 14:34:12,845 [INFO] root: Registry: [‘nvcr.io’]
2021-08-23 14:34:13,236 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the ~/.tlt_mounts.json file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-08-23 06:34:22,685 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-08-23 06:34:22,686 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:57: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2021-08-23 06:34:22,836 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:57: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:60: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-08-23 06:34:22,837 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:60: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:61: The name tf.keras.backend.set_session is deprecated. Please use tf.compat.v1.keras.backend.set_session instead.
2021-08-23 06:34:23,513 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:61: The name tf.keras.backend.set_session is deprecated. Please use tf.compat.v1.keras.backend.set_session instead.
2021-08-23 06:34:23,514 [INFO] iva.lprnet.utils.spec_loader: Merging specification from /workspace/tlt-experiments/lprnet/tutorial_spec.txt
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py”, line 277, in
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py”, line 273, in main
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py”, line 64, in run_experiment
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/utils/spec_loader.py”, line 126, in load_experiment_spec
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/utils/spec_loader.py”, line 106, in load_proto
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/utils/spec_loader.py”, line 92, in _load_from_file
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 735, in Merge
allow_unknown_field=allow_unknown_field)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 803, in MergeLines
return parser.MergeLines(lines, message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 828, in MergeLines
self._ParseOrMerge(lines, message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 850, in _ParseOrMerge
self._MergeField(tokenizer, message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 980, in _MergeField
merger(tokenizer, message, field)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 1055, in _MergeMessageField
self._MergeField(tokenizer, sub_message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 947, in _MergeField
(message_descriptor.full_name, name))
google.protobuf.text_format.ParseError: 57:5 : Message type “AugmentationConfig” has no field named “transform_prob”.
2021-08-23 14:34:25,207 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
