Hi, running jarvis_init.sh i get 2 errors that don’t seem blocking.
But then during the download of the models I get a timeout and I can’t download the templates.
Please can you help me on the resolution of this 3 errors ?
Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION. All rights reserved.
NVIDIA modifications are covered by the license terms that apply to the underlying
project or file.
find: File system loop detected; ‘/usr/bin/X11’ is part of the same file system loop as ‘/usr/bin’.
NOTE: The SHMEM allocation limit is set to the default of 64MB. This may be
insufficient for the inference server. NVIDIA recommends the use of the following flags:
nvidia-docker run --shm-size=1g --ulimit memlock=-1 --ulimit stack=67108864 …
/data/artifacts /opt/jarvis
Downloading nvidia/jarvis/jmir_punctuation:1.0.0-b.1…
HTTPSConnectionPool(host=‘authn.nvidia.com’, port=443): Read timed out. (read timeout=30)
Attempt 1 out of 3 failed
Trying again…
Attempt 2 out of 3 failed
Trying again…
Attempt 3 out of 3 failed
Error occurred downloading ‘nvidia/jarvis/jmir_punctuation:1.0.0-b.1’. Exiting.
Error in downloading models.
However, the problem during download of the models remains blocking.
i tried pinging authn.nvidia.com but it doesn’t respond.
do you have any information to give me?
sudo bash jarvis_init.sh
Please enter API key for ngc.nvidia.com:
Logging into NGC docker registry if necessary...
Pulling required docker images if necessary...
Note: This may take some time, depending on the speed of your Internet connection.
> Pulling Jarvis Speech Server images.
> Image nvcr.io/nvidia/jarvis/jarvis-speech:1.2.1-beta-server exists. Skipping.
> Image nvcr.io/nvidia/jarvis/jarvis-speech-client:1.2.1-beta exists. Skipping.
> Image nvcr.io/nvidia/jarvis/jarvis-speech:1.2.1-beta-servicemaker exists. Skipping.
Downloading models (JMIRs) from NGC...
Note: this may take some time, depending on the speed of your Internet connection.
To skip this process and use existing JMIRs set the location and corresponding flag in config.sh.
== Jarvis Speech Skills ==
NVIDIA Release devel (build 22382700)
Copyright (c) 2018-2021, NVIDIA CORPORATION. All rights reserved.
project or file.
ERROR: This container was built for NVIDIA Driver Release 465.19 or later, but
version 460.67 was detected and compatibility mode is UNAVAILABLE.
[[Forward compatibility was attempted on non supported HW (CUDA_ERROR_COMPAT_NOT_SUPPORTED_ON_DEVICE) cuInit()=804]]
nvidia-docker run --shm-size=1g --ulimit memlock=-1 --ulimit stack=67108864 ...
> Downloading nvidia/jarvis/jmir_punctuation:1.2.0-beta...
HTTPSConnectionPool(host='authn.nvidia.com', port=443): Read timed out. (read timeout=30)
> Trying again...
> Trying again...
Error occurred downloading 'nvidia/jarvis/jmir_punctuation:1.2.0-beta'. Exiting.
SOLUTION: after disconnecting from my proxy service, i was able to download the models
furthermore, i had problems with this supoort forum, and was unable to make this comment via chrome and had to switch to firefox
