Error in installing Deepstream SDK
  1. when i do deepstream-app -c samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
output:
root@utkarsh:/opt/nvidia/deepstream/deepstream-6.4# deepstream-app -c samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
(gst-plugin-scanner:927): GStreamer-WARNING **: 06:21:15.848: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.1: cannot open shared object file: No such file or directory
Authorization required, but no authorization protocol specified
** ERROR: main:716: Failed to set pipeline to PAUSED
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=2
nvstreammux: Successfully handled EOS for source_id=3
App run failed
  1. I have also installed additional packages by /opt/nvidia/deepstream/deepstream/user_additional_install.sh
