I am trying to run the example with the NVIDIA modulus 22.07 container. Everything run fine until examples that contain the use of ZeroEquation which require to compute the sdf derivatives. (Example code: ldc/ldc_2d_zeroEq.py
, three_fin_2d/heat_sink.py
). I always get the following error when running the code.
File "/modulus/modulus/solver/solver.py", line 159, in solve
self._train_loop(sigterm_handler)
File "/modulus/modulus/trainer.py", line 554, in _train_loop
self._record_monitors(step)
File "/modulus/modulus/trainer.py", line 298, in _record_monitors
self.record_monitors(step)
File "/modulus/modulus/solver/solver.py", line 148, in record_monitors
self.domain.rec_monitors(self.network_dir, self.writer, step)
File "/modulus/modulus/domain/domain.py", line 102, in rec_monitors
monitor.save_results(key, writer, step, monitor_data_dir)
File "/modulus/modulus/domain/monitor/pointwise.py", line 59, in save_results
outvar = self.model(invar)
File "/opt/conda/lib/python3.8/site-packages/torch/nn/modules/module.py", line 1129, in _call_impl
return forward_call(*input, **kwargs)
File "/modulus/modulus/graph.py", line 157, in forward
outvar.update(e(outvar))
RuntimeError: The following operation failed in the TorchScript interpreter.
Traceback of TorchScript (most recent call last):
File "/modulus/modulus/eq/derivatives.py", line 85, in forward
var = input_var[var_name]
grad_var = self.prepare_input(input_var, grad_sizes.keys())
grad = gradient(var, grad_var)
~~~~~~~~ <--- HERE
grad_dict = {
name: grad[i] for i, name in enumerate(self.gradient_names[var_name])
File "/modulus/modulus/eq/derivatives.py", line 24, in gradient
grad_outputs: List[Optional[torch.Tensor]] = [torch.ones_like(y, device=y.device)]
grad = torch.autograd.grad(
~~~~~~~~~~~~~~~~~~~ <--- HERE
y,
RuntimeError: element 0 of tensors does not require grad and does not have a grad_fn
I am suspecting there is some bug in initializing the variable without the required_grad
option enable. Anyone can give some suggestion on how to run these examples ?
