Pytorch grad issue while using solve in derivatives
I have been trying to develop and run a custom model for my physics informed NN, but I don’t understand the issue faced
Script:
# libraries
from sympy import Symbol, Function, exp, Number
from modulus.sym.eq.pde import PDE
from modulus.sym.node import Node
from sympy import Symbol, Eq
import numpy as np
import modulus.sym
from modulus.sym.hydra import instantiate_arch, ModulusConfig
from modulus.sym.models.layers import Activation
from modulus.sym.solver import Solver
from modulus.sym.domain import Domain
from modulus.sym.geometry.primitives_2d import Rectangle, Circle
from modulus.sym.domain.constraint import (
    PointwiseBoundaryConstraint,
    PointwiseInteriorConstraint,
from modulus.sym.domain.validator import PointwiseValidator
from modulus.sym.domain.inferencer import PointwiseInferencer
from modulus.sym.key import Key
from modulus.sym.models.fully_connected import FullyConnectedArch
from modulus.sym.models.deeponet import DeepONetArch
E = 10
nu = 0.33
class damage_model(PDE):
    name = "damage_model"
    def __init__(self, E, nu, rho = 1e4, beta=1/8100, r1 = 1e4, r2 = 1e4, dim =2, time =True):
        self.sim = dim
        self.time = time
        # space coordinates
        x = Symbol("x")
        y = Symbol("y")
        # plane normals
        normal_x, normal_y= (
            Symbol("normal_x"),
            Symbol("normal_y"),
        # time coordinate
        t = Symbol("t")
        # functionality
        input_variables = {"x": x, "y": y, "t": t}
        # material properties
        if E is None:
            E = Function("E", positive = True)(*input_variables)
        if E is None:
            nu = Function("nu", positive = True)(*input_variables)
        # LE terms
        lambda_ = nu * E / ((1 + nu) * (1 - 2 * nu))
        mu = E / (2 * (1 + nu))
        # displacement fields
        u = Function("u")(*input_variables)
        v = Function("v")(*input_variables)
        # damage field
        d = Function("d", nonnegative = True)(*input_variables)
        # damage function:
        f = 1 - exp(-d)
        # strains
        e_xx = u.diff(x)
        e_yy = v.diff(y)
        e_xy = 0.5*(v.diff(x) + u.diff(y))
        # stress fields
        w_z = -lambda_ / (lambda_ + 2 * mu) * (u.diff(x) + v.diff(y))
        sigma_xx = lambda_ * (u.diff(x) + v.diff(y) + w_z) + 2 * mu * u.diff(x)
        sigma_yy = lambda_ * (u.diff(x) + v.diff(y) + w_z) + 2 * mu * v.diff(y)
        sigma_xy = mu * (u.diff(y) + v.diff(x))
        # set equations
        self.equations = {}
        # stress equations as per Linear Elasticity
        self.equations["LE_sigma_xx"] = sigma_xx
        self.equations["LE_sigma_yy"] = sigma_yy
        self.equations["LE_sigma_xy"] = sigma_xy
        # Equations of equilibrium
        self.equations["eq_x"] = rho * ((u.diff(t)).diff(t)) - (sigma_xx.diff(x) + sigma_xy.diff(y))
        self.equations["eq_y"] = rho * ((v.diff(t)).diff(t)) - (sigma_xy.diff(x) + sigma_yy.diff(y))
        # Traction equations
        self.equations["tr_x"] = normal_x * sigma_xx + normal_y * sigma_xy
        self.equations["tr_y"] = normal_x * sigma_xy + normal_y * sigma_yy
        # LE energy: phi_{0}
        self.equations["phi_0"] = 0.5*(sigma_xx*e_xx + sigma_yy*e_yy + 2*sigma_xy*e_xy)
        # damge function
        self.equations["f"] = f
        # distorsion energy
        self.equations["phi"] = f*self.equations["phi_0"] + 0.5*beta*((f.diff(x))**2 + (f.diff(y))**2)
        # /delta^{diss}
        self.equations["diss"] = r1*(((f.diff(t))**2)**0.5) + 0.5*r2*((f.diff(t))**2)
        # p
        self.equations["p"] = -1*self.equations["phi_0"] + beta*(f.diff(x, 2) + f.diff(y, 2))
        # p_hat
        self.equations["p_hat"] = self.equations["p"] - r1
        # p_plus
        self.equations["p_plus"] = 0.5*(self.equations["p_hat"] + (self.equations["p_hat"]**2)**0.5)
        # DM
        self.equations["DM"] = r2*(f.diff(t)) + self.equations["p_plus"]
# running the model
@modulus.sym.main(config_path="config", config_name="conf")
def run(cfg: ModulusConfig) -> None:
    equations = damage_model(E = E, nu = nu)
    damage_net = instantiate_arch(
        input_keys = [
            Key("x"),
            Key("y"),
            Key("t")
        output_keys = [
            Key("u"),
            Key("v"),
            Key("d")
        cfg = cfg.arch.fully_connected,
        activation_fn=Activation.TANH,
    nodes = equations.make_nodes() + [damage_net.make_node(name="damage_net")]
    panel_origin = (0, 0)
    panel_left_bottom = (-1, -2)
    panel_right_top = (1, 2)
    panel = Rectangle(panel_left_bottom, panel_right_top)
    cut = Circle(panel_origin, radius = 0.2)
    geo = panel - cut
    x = Symbol("x")
    y = Symbol("y")
    t_symbol = Symbol("t")
    bound_x = (panel_left_bottom[0], panel_right_top[0])
    bound_y = (panel_left_bottom[1], panel_right_top[1])
    bound_t = (0.0, 1.0)
    time_range = {t_symbol: bound_t}
    domain = Domain()
    left = PointwiseBoundaryConstraint(
        nodes = nodes,
        geometry = geo,
        outvar = {
            "tr_x" : 0.0,
            "tr_y": 0.0,
        batch_size = cfg.batch_size.panel_left,
        criteria = Eq(x, panel_left_bottom[0]),
        parameterization=time_range,
        batch_per_epoch=500,
    domain.add_constraint(left, "BC_left")
    right = PointwiseBoundaryConstraint(
        nodes = nodes,
        geometry = geo,
        outvar = {
            "tr_x" : 0.0,
            "tr_y": 0.0,
        batch_size = cfg.batch_size.panel_right,
        criteria = Eq(x, panel_right_top[0]),
    domain.add_constraint(right, "BC_right")
    cutting = PointwiseBoundaryConstraint(
        nodes = nodes,
        geometry = cut,
        outvar = {
            "tr_x" : 0.0,
            "tr_y": 0.0,
    domain.add_constraint(cutting, "BC_cutting")
    panel_bottom = PointwiseBoundaryConstraint(
            nodes=nodes,
            geometry=geo,
            outvar = {"v": 0.0, "d": 0.0},
            batch_size = cfg.batch_size.panel_bottom,
            criteria = Eq(y, panel_left_bottom[1]),
    domain.add_constraint(panel_bottom, "panel_bottom")
    panel_top = PointwiseBoundaryConstraint(
            nodes=nodes,
            geometry=geo,
            outvar={"v": 0.01*t_symbol},
            batch_size = cfg.batch_size.panel_top,
            criteria = Eq(y, panel_right_top[1]),
    domain.add_constraint(panel_top, "panel_top")
    IC = PointwiseInteriorConstraint(
        nodes = nodes,
        geometry = geo,
        outvar={"u": 0.0, "v":0.0, "d": 0.0},
        batch_size=cfg.batch_size.interior,
        lambda_weighting={
            "u": 100.0,
            "v": 100.0,
            "d": 100.0,
    domain.add_constraint(IC, "IC")
    # low-resolution interior
    lr_interior = PointwiseInteriorConstraint(
        nodes=nodes,
        geometry=geo,
        outvar={
            "eq_x": 0.0,
            "eq_y": 0.0,
            # "stress_disp_xx": 0.0,
            # "stress_disp_yy": 0.0,
            # "stress_disp_xy": 0.0,
            "DM": 0.0
        bounds={x: bound_x, y: bound_y,},
        lambda_weighting={
            "eq_x": Symbol("sdf"),
            "eq_y": Symbol("sdf"),
            # "stress_disp_xx": Symbol("sdf"),
            # "stress_disp_yy": Symbol("sdf"),
            # "stress_disp_xy": Symbol("sdf"),
            "DM": Symbol("sdf"),
    domain.add_constraint(lr_interior, "lr_interior")
    for i, specific_time in enumerate(np.linspace(0, bound_t[1], 10)):
        invar_numpy = geo.sample_interior(
            1000000,
            bounds={x: bound_x, y: bound_y},
            parameterization={t_symbol: specific_time},
        grid_inference = PointwiseInferencer(
            nodes=nodes,
            invar=invar_numpy,
            output_names=["u", "v", "d", "f", "phi", "LE_sigma_xx", "LE_sigma_yy", "LE_sigma_xy"],
            batch_size=4096,
        domain.add_inferencer(grid_inference, name="time_slice_" + str(i+1).zfill(3))
    # make solver
    slv = Solver(cfg, domain)
    # start solver
    slv.solve()
if __name__ == "__main__":
    run()
The error I am facing:
    grad_outputs: List[Optional[torch.Tensor]] = [torch.ones_like(y, device=y.device)]
    grad = torch.autograd.grad(
           ~~~~~~~~~~~~~~~~~~~ <--- HERE
            y,
RuntimeError: element 0 of tensors does not require grad and does not have a grad_fn
which arises in the side script:
# Copyright (c) 2023, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
#     http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import itertools
import torch
import numpy as np
import logging
from torch.autograd import Function
from modulus.sym.constants import diff
from modulus.sym.eq.mfd import FirstDeriv, SecondDeriv, ThirdDeriv, ForthDeriv
from typing import Dict, List, Set, Optional, Union, Callable
Tensor = torch.Tensor
logger = logging.getLogger(__name__)
# ==== Autodiff ====
@torch.jit.script
def gradient(y: torch.Tensor(), x: List[torch.Tensor]) -> List[torch.Tensor]:
    TorchScript function to compute the gradient of a tensor wrt multiple inputs
            y,
        x,
        grad_outputs=grad_outputs,
        create_graph=True,
        allow_unused=True,
    if grad is None:
        grad = [torch.zeros_like(xx) for xx in x]
    assert grad is not None
    grad = [g if g is not None else torch.zeros_like(x[i]) for i, g in enumerate(grad)]
    return grad
class Derivative(torch.nn.Module):
    Module to compute derivatives using backward automatic differentiation
    def __init__(self, bwd_derivative_dict: Dict[Key, List[Key]]):
        Constructor of the Derivative class.
        Parameters
        inputs : List[Key]
            A list of keys of the available variables to compute the required variables
            This list should contain both the variables that need to be differentiated
            and the variables to differentiate with respect to.
        derivatives : List[Key]
            A list of keys of the required derivatives
        super().__init__()
        self.gradient_dict: Dict[str, Dict[str, int]] = {
            str(k): {str(w): w.size for w in v} for k, v in bwd_derivative_dict.items()
        self.gradient_names: Dict[str, List[str]] = {
            k: [diff(k, der) for der in v.keys()] for k, v in self.gradient_dict.items()
        self.nvtx_str: str = f"Auto-Diff Node: {list(self.gradient_dict.keys())}"
    @staticmethod
    def prepare_input(
        input_variables: Dict[str, torch.Tensor], mask: List[str]
        return [input_variables[x] for x in mask]
    @staticmethod
    def dict_output(
        output_tensors: List[torch.Tensor], sizes: List[str], var_name: str
    ) -> Dict[str, torch.Tensor]:
        return {diff(var_name, name): output_tensors[i] for i, name in enumerate(sizes)}
    def forward(self, input_var: Dict[str, torch.Tensor]) -> Dict[str, torch.Tensor]:
        output_var = {}
        for var_name, grad_sizes in self.gradient_dict.items():
            var = input_var[var_name]
            grad_var = self.prepare_input(input_var, grad_sizes.keys())
            grad = gradient(var, grad_var)
            grad_dict = {
                name: grad[i] for i, name in enumerate(self.gradient_names[var_name])
            output_var.update(grad_dict)
        return output_var
    @classmethod
    def make_node(cls, inputs: List[Key], derivatives: List[Key], name=None, jit=True):
        derivatives = [d for d in derivatives if d not in inputs]
        bwd_derivative_dict = _derivative_dict(inputs, derivatives, forward=False)
        output_derivatives = []
        for key, value in bwd_derivative_dict.items():
            output_derivatives += [
                Key(key.name, key.size, key.derivatives + [x]) for x in value
        evaluate = cls(bwd_derivative_dict)
        nvtx_str = evaluate.nvtx_str
        if jit:
            evaluate = torch.jit.script(evaluate)
        derivative_node = Node(
            inputs,
            output_derivatives,
            evaluate,
            name=(nvtx_str if name is None else str(name)),
        return derivative_node
def _derivative_dict(var, derivatives, forward=False):
    needed = derivatives
    while True:  # break apart diff to see if first order needed
        break_loop = True
        for n in needed:
            l_n = Key(n.name, n.size, n.derivatives[:-1])
            if (len(n.derivatives) > 1) and l_n not in needed and l_n not in var:
                needed.append(l_n)
                break_loop = False
        if break_loop:
            break
    current = var
    diff_dict = {}
    for c, n in itertools.product(current, needed):
        c_under_n = Key(n.name, n.size, n.derivatives[0 : len(c.derivatives)])
        if (c == c_under_n) and (len(n.derivatives) == len(c.derivatives) + 1):
            if forward:
                if n.derivatives[len(c.derivatives)] not in diff_dict:
                    diff_dict[n.derivatives[len(c.derivatives)]] = set()
                diff_dict[n.derivatives[len(c.derivatives)]].add(c)
            else:
                if c not in diff_dict:
                    diff_dict[c] = set()
                diff_dict[c].add(n.derivatives[len(c.derivatives)])
    diff_dict = {key: list(value) for key, value in diff_dict.items()}
    return diff_dict
# ==== Meshless finite derivs ====
class MeshlessFiniteDerivative(torch.nn.Module):
    Module to compute derivatives using meshless finite difference
    Parameters
    model : torch.nn.Module
        Forward torch module for calculating stencil values
        List of derivative keys to calculate
    dx : Union[float, Callable]
        Spatial discretization of all axis, can be function with parameter `count` which is
        the number of forward passes for dynamically adjusting dx
    order : int, optional
        Order of derivative, by default 2
    max_batch_size : Union[int, None], optional
        Max batch size of stencil calucations, by default uses batch size of inputs
    double_cast : bool, optional
        Cast fields to double precision to calculate derivatives, by default True
    jit : bool, optional
        Use torch script for finite deriv calcs, by default True
    def __init__(
        self,
        model: torch.nn.Module,
        dx: Union[float, Callable],
        order: int = 2,
        max_batch_size: Union[int, None] = None,
        double_cast: bool = True,
        input_keys: Union[List[Key], None] = None,
        super().__init__()
        self.model = model
        self._dx = dx
        self.double_cast = double_cast
        self.max_batch_size = max_batch_size
        self.input_keys = input_keys
        self.count = 0
        self.derivatives = {1: [], 2: [], 3: [], 4: []}
        for key in derivatives:
            try:
                self.derivatives[len(key.derivatives)].append(key)
            except:
                raise NotImplementedError(
                    f"{len(key.derivatives)}th derivatives not supported"
        self.first_deriv = FirstDeriv(self.derivatives[1], self.dx, order=order)
        self.second_deriv = SecondDeriv(self.derivatives[2], self.dx, order=order)
        self.third_deriv = ThirdDeriv(self.derivatives[3], self.dx, order=order)
        self.forth_deriv = ForthDeriv(self.derivatives[4], self.dx, order=order)
    @torch.jit.ignore()
    def forward(self, inputs: Dict[str, torch.Tensor]) -> Dict[str, torch.Tensor]:
        self.count += 1
        dx = self.dx
        self.first_deriv.dx = dx
        self.second_deriv.dx = dx
        self.third_deriv.dx = dx
        self.forth_deriv.dx = dx
        torch.cuda.nvtx.range_push(f"Calculating meshless finite derivatives")
        # Assemble global stencil
        global_stencil = []
        for deriv in [
            self.first_deriv,
            self.second_deriv,
            self.third_deriv,
            self.forth_deriv,
            stencil_list = deriv.stencil
            # Remove centered stencil points if already in input dictionary
            for i, point in enumerate(stencil_list):
                if point.split("::")[1] == str(0) and point.split("::")[0] in inputs:
                    stencil_list.pop(i)
            global_stencil.extend(stencil_list)
        global_stencil = list(set(global_stencil))
        # Number of stencil points to fit into a forward pass
        input_batch_size = next(iter(inputs.values())).size(0)
        if self.max_batch_size is None:
            num_batch = 1
        else:
            num_batch = max([self.max_batch_size, input_batch_size]) // input_batch_size
        # Stencil forward passes
        index = 0
        finite_diff_inputs = inputs.copy()
        while index < len(global_stencil):
            torch.cuda.nvtx.range_push(f"Running stencil forward pass")
            # Batch up stencil inputs
            stencil_batch = [global_stencil[index]]
            index += 1
            for j in range(1, min([len(global_stencil) - (index - 1), num_batch])):
                stencil_batch.append(global_stencil[index])
                index += 1
            model_inputs = self._get_stencil_input(inputs, stencil_batch)
            # Model forward
            outputs = self.model(model_inputs)
            # Dissassemble batched inputs
            for key, value in outputs.items():
                outputs[key] = torch.split(value.view(-1, len(stencil_batch)), 1, dim=1)
            for i, stencil_str in enumerate(stencil_batch):
                    finite_diff_inputs[f"{key}>>{stencil_str}"] = value[i]
            torch.cuda.nvtx.range_pop()
        # Calc finite diff grads
        torch.cuda.nvtx.range_push(f"Calc finite difference")
        if self.double_cast:  # Cast tensors to doubles for finite diff calc
            for key, value in finite_diff_inputs.items():
                finite_diff_inputs[key] = value.double()
        outputs_first = self.first_deriv(finite_diff_inputs)
        outputs_second = self.second_deriv(finite_diff_inputs)
        outputs_third = self.third_deriv(finite_diff_inputs)
        outputs_forth = self.forth_deriv(finite_diff_inputs)
        outputs = inputs
            dtype = torch.get_default_dtype()
            for key, value in outputs_first.items():
                outputs_first[key] = value.type(dtype)
            for key, value in outputs_second.items():
                outputs_second[key] = value.type(dtype)
            for key, value in outputs_third.items():
                outputs_third[key] = value.type(dtype)
            for key, value in outputs_forth.items():
                outputs_forth[key] = value.type(dtype)
        outputs = {
            **inputs,
            **outputs_first,
            **outputs_second,
            **outputs_third,
            **outputs_forth,
        return outputs
    @property
    def dx(self):
        if hasattr(self._dx, "__call__"):
            return self._dx(self.count)
        else:
            return self._dx
    def _get_stencil_input(
        self, inputs: Dict[str, Tensor], stencil_strs: List[str]
    ) -> Dict[str, Tensor]:
        """Creates a copy of the inputs tensor and adjusts its values based on
        the stencil str.
        Parameters
        inputs : Dict[str, Tensor]
            Input tensor dictionary
        stencil_strs : List[str]
            batch list of stencil string from derivative class
        Returns
        Dict[str, Tensor]
            Modified input tensor dictionary
        Example
        A stencil string `x::1` will modify inputs['x'] = inputs['x'] + dx
        A stencil string `y::-1,z::1` will modify inputs['y'] = inputs['y'] - dx, inputs['z'] = inputs['z'] + dx
        if self.input_keys is None:
            outputs = inputs.copy()
        else:
            outputs = {str(key): inputs[str(key)].clone() for key in self.input_keys}
            outputs[key] = value.repeat(1, len(stencil_strs))
        for i, stencil_str in enumerate(stencil_strs):
            # Loop through points
            for point in stencil_str.split("&&"):
                var_name = point.split("::")[0]
                spacing = int(point.split("::")[1])
                outputs[var_name][:, i] = outputs[var_name][:, i] + spacing * self.dx
            outputs[key] = value.view(-1, 1)
        return outputs
    @classmethod
    def make_node(
        cls,
        node_model: Union[Node, torch.nn.Module],
        order: int = 2,
        name: str = None,
        input_keys: Union[List[Key], List[str], None] = None,
        """Makes a meshless finite derivative node.
        Parameters
        node_model : Union[Node, torch.nn.Module]
            Node or torch.nn.Module for computing FD stencil values.
            Part of the inputs to this model should consist of the independent
            variables and output the functional value
            List of derivatives to be computed
            Spatial discretization for finite diff calcs, can be function
            Order of accuracy of finite diff calcs, by default 2
            Maximum batch size to used with the stenicl foward passes, by default None
            Name of node, by default None
            Cast tensors to double precision for derivatives, by default True
        input_keys : Union[List[Key], List[str], None], optional
            List of input keys to be used for input of forward model.
            Should be used if node_model is not a :obj:`Node`, by default None
        # We have two sets of input keys:
        # input_keys: which are the list of inputs to the model for stencil points
        # mfd_input_keys: input keys for the MFD node
        if input_keys is None:
            input_keys = []
            mfd_input_keys = []
        else:
            input_keys = [str(key) for key in input_keys]
            mfd_input_keys = [str(key) for key in input_keys]
        for derivative in derivatives:
            mfd_input_keys.append(derivative.name)
            for dstr in derivative.derivatives:
                mfd_input_keys.append(dstr.name)
        if isinstance(node_model, Node):
            model = node_model.evaluate
            input_keys = input_keys + [str(key) for key in node_model.inputs]
        else:
            model = node_model
        # Remove duplicate keys
        mfd_input_keys = Key.convert_list(list(set(mfd_input_keys)))
        input_keys = Key.convert_list(list(set(input_keys)))
        evaluate = cls(
            model,
            derivatives,
            dx=dx,
            order=order,
            max_batch_size=max_batch_size,
            double_cast=double_cast,
            input_keys=input_keys,
            mfd_input_keys,
            derivatives,
            evaluate,
            name=(
                "Meshless-Finite-Derivative Node" + "" if name is None else f": {name}"
You see, the variable “y” is defined in the side script, and I am unable to enable require_grad as recommended online.
Please help me out with this issue. I would be really obliged if you could please help me out @ngeneva
According to me this file should run without any issues
Thank you
Hi @nihalpushkar11
Do you know precisely which constraint / inferencer is causing this error. If not could you isolate it? This is happening because you are requesting a gradient that cant be computed because it has not been registered with auto-grad to record its gradients (this is what requires_grad does).
hi @ngeneva
sorry for not mentioning earlier, but this error is encounter on adding the inferencer, thank you for you advice i was now able to review that one of the variable was not enabled with “requires_grad” and hence it was not running.
removing that variable solved the issue, but how can add that variable with auto-grad? could you please recommend some documentations?
Thanks and regards
Nihal
Hi @nihalpushkar11
This is typically handled for inputs using the requires_grad=True inference parameter, however you mentioned here that doesn’t work for some reason. Otherwise variables inside the symbolic graph allow gradients to be calculated.
Which variable did you remove?
Apologies, Actually I was editting the require_grad = True in the wrong file. Your solution worked, Thank you
