Hi all.
I created a tensorrt engine from a pytorch model using onnx intermediate representation. The model is OSNet, which has two versions, osnet_x1_0 which is the whole model and x0_25 which has all the filter channels reduced by 4 times(no of channels / 4). I created separate engines for both the models,batches of sizes 1, 5 and 10 and precisions of fp16 and fp32. I have given the inference times for each batch in milliseconds.For batch size of 1, there is no difference between osnetx1_0 and osnetx0_25 and also between fp16 and fp32, which is surprising. Request somebody to explain it.
Device running on: Jetson Tx2
OS: Ubuntu 16.04
TensorRT version: 6
from __future__ import absolute_import
from __future__ import division
__all__ = ['osnet_x1_0', 'osnet_x0_75', 'osnet_x0_5', 'osnet_x0_25', 'osnet_ibn_x1_0']
import torch
from torch import nn
from torch.nn import functional as F
#import torchvision
pretrained_urls = {
'osnet_x1_0': 'https://drive.google.com/uc?id=1LaG1EJpHrxdAxKnSCJ_i0u-nbxSAeiFY',
'osnet_x0_75': 'https://drive.google.com/uc?id=1uwA9fElHOk3ZogwbeY5GkLI6QPTX70Hq',
'osnet_x0_5': 'https://drive.google.com/uc?id=16DGLbZukvVYgINws8u8deSaOqjybZ83i',
'osnet_x0_25': 'https://drive.google.com/uc?id=1rb8UN5ZzPKRc_xvtHlyDh-cSz88YX9hs',
'osnet_ibn_x1_0': 'https://drive.google.com/uc?id=1sr90V6irlYYDd4_4ISU2iruoRG8J__6l'
# Basic layers
class ConvLayer(nn.Module):
"""Convolution layer (conv + bn + relu)."""
def __init__(self, in_channels, out_channels, kernel_size, stride=1, padding=0, groups=1, IN=False):
super(ConvLayer, self).__init__()
self.conv = nn.Conv2d(in_channels, out_channels, kernel_size, stride=stride,
padding=padding, bias=False, groups=groups)
if IN:
self.bn = nn.InstanceNorm2d(out_channels, affine=True)
else:
self.bn = nn.BatchNorm2d(out_channels)
self.relu = nn.ReLU(inplace=True)
def forward(self, x):
x = self.conv(x)
x = self.bn(x)
x = self.relu(x)
return x
class Conv1x1(nn.Module):
"""1x1 convolution + bn + relu."""
def __init__(self, in_channels, out_channels, stride=1, groups=1):
super(Conv1x1, self).__init__()
self.conv = nn.Conv2d(in_channels, out_channels, 1, stride=stride, padding=0,
x = self.conv(x)
x = self.bn(x)
x = self.relu(x)
return x
class Conv1x1Linear(nn.Module):
"""1x1 convolution + bn (w/o non-linearity)."""
def __init__(self, in_channels, out_channels, stride=1):
super(Conv1x1Linear, self).__init__()
self.conv = nn.Conv2d(in_channels, out_channels, 1, stride=stride, padding=0, bias=False)
x = self.conv(x)
x = self.bn(x)
return x
class Conv3x3(nn.Module):
"""3x3 convolution + bn + relu."""
super(Conv3x3, self).__init__()
self.conv = nn.Conv2d(in_channels, out_channels, 3, stride=stride, padding=1,
x = self.conv(x)
x = self.bn(x)
x = self.relu(x)
return x
class LightConv3x3(nn.Module):
"""Lightweight 3x3 convolution.
1x1 (linear) + dw 3x3 (nonlinear).
def __init__(self, in_channels, out_channels):
super(LightConv3x3, self).__init__()
self.conv1 = nn.Conv2d(in_channels, out_channels, 1, stride=1, padding=0, bias=False)
self.conv2 = nn.Conv2d(out_channels, out_channels, 3, stride=1, padding=1, bias=False, groups=out_channels)
x = self.conv1(x)
x = self.conv2(x)
x = self.bn(x)
x = self.relu(x)
return x
# Building blocks for omni-scale feature learning
class ChannelGate(nn.Module):
"""A mini-network that generates channel-wise gates conditioned on input tensor."""
def __init__(self, in_channels, num_gates=None, return_gates=False,
gate_activation='sigmoid', reduction=16, layer_norm=False):
super(ChannelGate, self).__init__()
if num_gates is None:
num_gates = in_channels
self.return_gates = return_gates
self.global_avgpool = nn.AdaptiveAvgPool2d(1)
self.fc1 = nn.Conv2d(in_channels, in_channels//reduction, kernel_size=1, bias=True, padding=0)
self.norm1 = None
if layer_norm:
self.norm1 = nn.LayerNorm((in_channels//reduction, 1, 1))
self.fc2 = nn.Conv2d(in_channels//reduction, num_gates, kernel_size=1, bias=True, padding=0)
if gate_activation == 'sigmoid':
self.gate_activation = nn.Sigmoid()
elif gate_activation == 'relu':
self.gate_activation = nn.ReLU(inplace=True)
elif gate_activation == 'linear':
self.gate_activation = None
else:
raise RuntimeError("Unknown gate activation: {}".format(gate_activation))
input = x
x = self.global_avgpool(x)
x = self.fc1(x)
if self.norm1 is not None:
x = self.norm1(x)
x = self.relu(x)
x = self.fc2(x)
if self.gate_activation is not None:
x = self.gate_activation(x)
if self.return_gates:
return x
return input * x
class OSBlock(nn.Module):
"""Omni-scale feature learning block."""
def __init__(self, in_channels, out_channels, IN=False, bottleneck_reduction=4, **kwargs):
super(OSBlock, self).__init__()
mid_channels = out_channels // bottleneck_reduction
self.conv1 = Conv1x1(in_channels, mid_channels)
self.conv2a = LightConv3x3(mid_channels, mid_channels)
self.conv2b = nn.Sequential(
LightConv3x3(mid_channels, mid_channels),
self.conv2c = nn.Sequential(
self.conv2d = nn.Sequential(
self.gate = ChannelGate(mid_channels)
self.conv3 = Conv1x1Linear(mid_channels, out_channels)
self.downsample = None
if in_channels != out_channels:
self.downsample = Conv1x1Linear(in_channels, out_channels)
self.IN = None
if IN:
self.IN = nn.InstanceNorm2d(out_channels, affine=True)
identity = x
x1 = self.conv1(x)
x2a = self.conv2a(x1)
x2b = self.conv2b(x1)
x2c = self.conv2c(x1)
x2d = self.conv2d(x1)
x2 = self.gate(x2a) + self.gate(x2b) + self.gate(x2c) + self.gate(x2d)
x3 = self.conv3(x2)
if self.downsample is not None:
identity = self.downsample(identity)
out = x3 + identity
if self.IN is not None:
out = self.IN(out)
return F.relu(out)
# Network architecture
class OSNet(nn.Module):
"""Omni-Scale Network.
Reference:
- Zhou et al. Omni-Scale Feature Learning for Person Re-Identification. ICCV, 2019.
def __init__(self, num_classes, blocks, layers, channels, feature_dim=512, loss='softmax', IN=False, **kwargs):
super(OSNet, self).__init__()
num_blocks = len(blocks)
assert num_blocks == len(layers)
assert num_blocks == len(channels) - 1
self.loss = loss
# convolutional backbone
self.conv1 = ConvLayer(3, channels[0], 7, stride=2, padding=3, IN=IN)
self.maxpool = nn.MaxPool2d(3, stride=2, padding=1)
self.conv2 = self._make_layer(blocks[0], layers[0], channels[0], channels[1], reduce_spatial_size=True, IN=IN)
self.conv3 = self._make_layer(blocks[1], layers[1], channels[1], channels[2], reduce_spatial_size=True)
self.conv4 = self._make_layer(blocks[2], layers[2], channels[2], channels[3], reduce_spatial_size=False)
self.conv5 = Conv1x1(channels[3], channels[3])
# fully connected layer
self.fc = self._construct_fc_layer(feature_dim, channels[3], dropout_p=None)
# identity classification layer
self.classifier = nn.Linear(self.feature_dim, num_classes)
self._init_params()
def _make_layer(self, block, layer, in_channels, out_channels, reduce_spatial_size, IN=False):
layers = []
layers.append(block(in_channels, out_channels, IN=IN))
for i in range(1, layer):
layers.append(block(out_channels, out_channels, IN=IN))
if reduce_spatial_size:
layers.append(
nn.Sequential(
Conv1x1(out_channels, out_channels),
nn.AvgPool2d(2, stride=2)
return nn.Sequential(*layers)
def _construct_fc_layer(self, fc_dims, input_dim, dropout_p=None):
if fc_dims is None or fc_dims<0:
self.feature_dim = input_dim
return None
if isinstance(fc_dims, int):
fc_dims = [fc_dims]
layers = []
for dim in fc_dims:
layers.append(nn.Linear(input_dim, dim))
layers.append(nn.BatchNorm1d(dim))
layers.append(nn.ReLU(inplace=True))
if dropout_p is not None:
layers.append(nn.Dropout(p=dropout_p))
input_dim = dim
self.feature_dim = fc_dims[-1]
def _init_params(self):
for m in self.modules():
if isinstance(m, nn.Conv2d):
nn.init.kaiming_normal_(m.weight, mode='fan_out', nonlinearity='relu')
if m.bias is not None:
nn.init.constant_(m.bias, 0)
elif isinstance(m, nn.BatchNorm2d):
nn.init.constant_(m.weight, 1)
elif isinstance(m, nn.BatchNorm1d):
elif isinstance(m, nn.Linear):
nn.init.normal_(m.weight, 0, 0.01)
def featuremaps(self, x):
x = self.conv1(x)
x = self.maxpool(x)
x = self.conv2(x)
x = self.conv3(x)
x = self.conv4(x)
x = self.conv5(x)
return x
def forward(self, x, return_featuremaps=False):
x = self.featuremaps(x)
if return_featuremaps:
return x
v = self.global_avgpool(x)
#v = v.view(v.size(0), -1)
v = v.view(9, 512)
if self.fc is not None:
v = self.fc(v)
if not self.training:
return v
# y = self.classifier(v)
# if self.loss == 'softmax':
# return v,y
# elif self.loss == 'triplet':
# return v,y
# else:
# raise KeyError("Unsupported loss: {}".format(self.loss))
def init_pretrained_weights(model, key=''):
"""Initializes model with pretrained weights.
Layers that don't match with pretrained layers in name or size are kept unchanged.
import os
import errno
import gdown
from collections import OrderedDict
def _get_torch_home():
ENV_TORCH_HOME = 'TORCH_HOME'
ENV_XDG_CACHE_HOME = 'XDG_CACHE_HOME'
DEFAULT_CACHE_DIR = '~/.cache'
torch_home = os.path.expanduser(
os.getenv(ENV_TORCH_HOME,
os.path.join(os.getenv(ENV_XDG_CACHE_HOME, DEFAULT_CACHE_DIR), 'torch')))
return torch_home
torch_home = _get_torch_home()
model_dir = os.path.join(torch_home, 'checkpoints')
try:
os.makedirs(model_dir)
except OSError as e:
if e.errno == errno.EEXIST:
# Directory already exists, ignore.
pass
else:
# Unexpected OSError, re-raise.
raise
filename = key + '_imagenet.pth'
cached_file = os.path.join(model_dir, filename)
if not os.path.exists(cached_file):
gdown.download(pretrained_urls[key], cached_file, quiet=False)
state_dict = torch.load(cached_file)
model_dict = model.state_dict()
new_state_dict = OrderedDict()
matched_layers, discarded_layers = [], []
for k, v in state_dict.items():
if k.startswith('module.'):
k = k[7:] # discard module.
if k in model_dict and model_dict[k].size() == v.size():
new_state_dict[k] = v
matched_layers.append(k)
model_dict.update(new_state_dict)
model.load_state_dict(model_dict)
if len(matched_layers) == 0:
warnings.warn(
'The pretrained weights from "{}" cannot be loaded, '
'please check the key names manually '
'(** ignored and continue **)'.format(cached_file))
else:
print('Successfully loaded imagenet pretrained weights from "{}"'.format(cached_file))
if len(discarded_layers) > 0:
print('** The following layers are discarded '
'due to unmatched keys or layer size: {}'.format(discarded_layers))
# Instantiation
def osnet_x1_0(num_classes=1000, pretrained=True, loss='softmax', **kwargs):
# standard size (width x1.0)
model = OSNet(num_classes, blocks=[OSBlock, OSBlock, OSBlock], layers=[2, 2, 2],
channels=[64, 256, 384, 512], loss=loss, **kwargs)
if pretrained:
init_pretrained_weights(model, key='osnet_x1_0')
return model
def osnet_x0_75(num_classes=1000, pretrained=True, loss='softmax', **kwargs):
# medium size (width x0.75)
channels=[48, 192, 288, 384], loss=loss, **kwargs)
if pretrained:
init_pretrained_weights(model, key='osnet_x0_75')
return model
def osnet_x0_5(num_classes=1000, pretrained=True, loss='softmax', **kwargs):
# tiny size (width x0.5)
channels=[32, 128, 192, 256], loss=loss, **kwargs)
if pretrained:
init_pretrained_weights(model, key='osnet_x0_5')
return model
def osnet_x0_25(num_classes=1000, pretrained=True, loss='softmax', **kwargs):
# very tiny size (width x0.25)
channels=[16, 64, 96, 128], loss=loss, **kwargs)
if pretrained:
init_pretrained_weights(model, key='osnet_x0_25')
return model
def osnet_ibn_x1_0(num_classes=1000, pretrained=True, loss='softmax', **kwargs):
# standard size (width x1.0) + IBN layer
# Ref: Pan et al. Two at Once: Enhancing Learning and Generalization Capacities via IBN-Net. ECCV, 2018.
channels=[64, 256, 384, 512], loss=loss, IN=True, **kwargs)
if pretrained:
init_pretrained_weights(model, key='osnet_ibn_x1_0')
return model
The inference code is:
import sys
import os
import trt_common as common
import cv2
import numpy as np
import datetime
import time
import traceback
import tensorrt as trt
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
import pycuda.driver as cuda
import pycuda.autoinit
engine_file_path = "/datadrive1/nafisa/reid/models/exp_x1_0_1_fp32.engine"
datadir = "/datadrive1/nafisa/reid/data/market/bounding_box_test"
def get_engine(engine_file_path=""):
"""Attempts to load a serialized engine if available, otherwise builds a new TensorRT engine and saves it."""
if os.path.exists(engine_file_path):
# If a serialized engine exists, use it instead of building an engine.
print("Reading engine from file {}".format(engine_file_path))
with open(engine_file_path, "rb") as f, trt.Runtime(TRT_LOGGER) as runtime:
return runtime.deserialize_cuda_engine(f.read())
else:
print("Engine not found")
return
def get_images(datadir, dtype, batch_size):
if(os.path.exists(datadir)):
imgpathlist = os.listdir(datadir)
imgpathlistlen = len(imgpathlist)
c, h, w = 3,256,128
for i in range(0,imgpathlistlen,batch_size):
batches= []
for j in range(0,batch_size,1):
if((i+j<imgpathlistlen) and os.path.exists(imgpathlist[i+j])):
img = cv2.imread(os.path.join(datadir,imgpathlist[i+j]))
img = cv2.resize(img,(128,256))
img = np.asarray(img)
img = img/255.0
img = (img - np.array([0.485, 0.456, 0.406])) / np.array([0.229, 0.224, 0.225])
img = img.transpose((2, 0, 1)).reshape((c, h, w))
#img = img.reshape((c, h, w))
if(dtype == "fp32"):
img = img.astype("float32")
elif(dtype== "fp16"):
img = img.astype("fp16")
else:
img = img.astype("int8")
batches.append(img)
len1 = len(batches)
batches =np.array(batches)
yield batches
else:
print("Data directory not found!")
yield None
engine = get_engine(engine_file_path)
context = engine.create_execution_context()
main_batch_size_user = 1
if __name__ == "__main__":
inference_time_list = []
trt_outputs = []
output_shapes = [(main_batch_size_user, 512)]
inputs, outputs, bindings, stream = common.allocate_buffers(engine)
count = 0
batches = get_images(datadir, "fp32", main_batch_size_user)
time_infer_mean = time_pre_mean= 0.0
for batch in batches:
t4 = time.time()
count+=1
print("Iterations {}".format(count))
inputs[0].host = batch
t2 = time.time()
for i in range(100):
trt_outputs = common.do_inference(context, bindings=bindings, inputs=inputs, outputs=outputs, stream=stream,batch_size=main_batch_size_user)
t3 = time.time()
infer_time = t3-t2
inference_time_list.append(infer_time)
if(count>200):
time_pre_mean = (time_pre_mean * (count-201) + (t4-t5))/(count-200)
time_infer_mean = (time_infer_mean * (count-201) + (t3-t2))/(count-200)
print("Time prep mean {}".format(time_pre_mean))
print("Time infer mean {}".format(time_infer_mean))
print("Time infer {}".format(t3-t2))
if(count==300):
break
t5 = time.time()
outputs = [output.reshape(shape) for output, shape in zip(trt_outputs, output_shapes)]
#nparray = np.array(outputs[0])
#np.save('models/trt_output_fp16.npy', nparray)
print("Done Dana Done!")
total_avg_time = sum(inference_time_list)/len(inference_time_list)
last_iters_time = sum(inference_time_list[200:])/len(inference_time_list[200:])
print("total_average:{}".format(total_avg_time))
print("last_iters_average:{}".format(last_iters_time))
The timings reported are of time_infer_mean for over 100 iterations taken after ignoring the first 200 iterations.
Link to the spreadsheet with timings:
https://docs.google.com/spreadsheets/d/1MuaYPpFMvulP249Te58iKGjjyI3nIdxePB8ka-DNdb0/edit?usp=sharing
