I’m trying to deploy a neural network on my Jetson Nano Card. When I use the command “make -f mytrainedNetworkFinalGPU_rtw.mk -j4 all”
An error occur :
“make: *** No rule to make target ‘/C/Users/lforz/OneDrive/Documents/trainednetwork119/codegen/lib/mytrainedNetworkFinalGPU/MWAvgPoolingLayer.cpp’, needed by ‘MWAvgPoolingLayer.o’. Stop.”
Where does it come from ? How could I fix it ? Maybe the Matlab code is not well compiled… I exported it using a Static Library build type in the Matlab GPU Coder, the toolchain is NVCC for NVDIA.
Thank you for your help,
Ludo
