Are you compiling from the command line or from within PVF?
It is a good guess that there may be a problem with an unquoted path. Check that you are quoting paths that contain spaces.
If you’re quoting all the paths that you can and the error still occurs, please add -v to the link line. Send the link command and its output to us so we can take a look.
