Hey guys here is my code of an lexical analyzer,
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include <regex>
#include <conio.h>
#include <stdio.h>
#include <stdlib.h>
#include <ctype.h>
#include <string>
#include <iostream>
#include <sstream>
#include <time.h>
#include <random>
#include <algorithm>
#include <map>
#include <vector>
using namespace std;
struct vetorCRelacaoAClasse
string dado;
string classe;
typedef struct vetorCRelacaoAClasse vcrac;
vector<string> lerArquivoEArmazenaVector(FILE *arq);
string stringComDataSet(vector<string> dataVetor);
string lerRelacao(string Linha_lida);
int qntClasses(string Linha_lida);
vector<string> lerClasses(string Linha_lida);
vector<string> lerAtributos(vector<string> Linha_lida);
int qntAtributos(vector<string> Linha_lida);
int indiceDeOcorrenciaDeData(vector<string> Linha_lida);
vector<string> conjuntoDeDados(vector<string> Linha_lida);
int instancias(vector<string> Linha_lida);
vector<string> explode(string Linha,string ER);
vector<vcrac> vectorDataSet(vector<string> conjuntoDeDados, vector<string> Linha_lida);
map<string,vector<vcrac>> finalDataSet(vector<string> vectorDataSet, vector<string> Linha_lida);
char Linha[100];
char *result;
vector<string> dataArff;
system("cls");
arq = fopen("Data/miniminiiris.arff", "rt");
if (arq == NULL)
cout<<"Arquivo nao encontrado"<<endl;
system("Pause");
exit(0);
else{
while (!feof(arq))
result = fgets(Linha, 100, arq);
if (result);
dataArff.push_back(result);
fclose(arq);
return dataArff;
const int n = dataVetor.size();
string data;
for(int i = 0; i< (int)(dataVetor.size());i++)
data += dataVetor[i];
return data;
regex rx1("^@RELATION.(.+)");
cmatch mr;
regex_search(Linha_lida.c_str(), mr, rx1);
string str= mr[1];
return str;
int qntClasse;
vector<string> classes;
regex rx1("^@ATTRIBUTE.class.(.+)$");
cmatch mr2;
regex_search(Linha_lida.c_str(), mr2, rx1);
string str2= mr2[1];
classes = explode(str2,",{} ");
qntClasse = classes.size();
return qntClasse;
cmatch mr2;
return classes;
vector<string> str;
for(int i=0; i<(int)(Linha_lida.size());i++)
regex rx("^@ATTRIBUTE.([a-zA-Z]+)");
cmatch mr;
if(regex_search(Linha_lida[i].c_str(), mr, rx))
str.push_back( mr[1]);
return str;
int qntAtributo = 0;
cmatch mr;
qntAtributo++;
return qntAtributo;
int data;
for(int i=0;i < (int)(Linha_lida.size());i++)
if (strstr(Linha_lida[i].c_str(),"@DATA"))
data = i;
break;
return data+1;
vector<string> conjuntoDeDados;
for(int i = indiceDeOcorrenciaDeData(Linha_lida); i<(int)(Linha_lida.size()); i++)
conjuntoDeDados.push_back(Linha_lida[i]);
return conjuntoDeDados;
int instancias = 0;
instancias++;
return instancias;
vector<string> explode;
char *cstr= new char [Linha.length()+1];
strcpy(cstr,Linha.c_str());
char *p = strtok (cstr,ER.c_str());
while (p!=0)
explode.push_back(p);
p = strtok(NULL,ER.c_str());
free(cstr);
return explode;
vector<string> dados;
vector<vcrac> vetorConjunto;
vcrac data;
for(int i = 0; i < (int)(conjuntoDeDados.size());i++)
dados = explode(conjuntoDeDados[i],",\n");
for(int j=0;j<(int)(dados.size());j++)
data.dado = dados[j];
data.classe = dados[dados.size() - 1];
vetorConjunto.push_back(data);
return vetorConjunto;
map<string,vector<vcrac>> finalDataSet(vector<vcrac> vectorDataSet, vector<string> Linha_lida)
vector<string> atributosVetor;
atributosVetor = lerAtributos(Linha_lida);
map<string, vector<vcrac>> mapa;
vector<vcrac> treino;
vcrac datas;
int constUniverso = qntAtributos(Linha_lida);
for(int consts=0;consts<constUniverso - 1;consts++)
treino.clear();
for(int i= consts;i<(int)(vectorDataSet.size());i = i + constUniverso)
datas.dado = vectorDataSet[i].dado;
datas.classe = vectorDataSet[i].classe;
treino.push_back(datas);
mapa[atributosVetor[consts]]=treino;
return mapa;
int main(void)
vector<string> dataSet;
vector<string> atributos;
vector<string> conjuntoDeDado;
FILE *arq = NULL;
string data = "";
string relacao = "";
map<string,vector<vcrac>> mapa;
vector<vcrac> vetorDeConjuntoDeDados;
dataSet = lerArquivoEArmazenaVector(arq);
data = stringComDataSet(dataSet);
relacao = lerRelacao(data);
classes = lerClasses(data);
atributos = lerAtributos(dataSet);
conjuntoDeDado = conjuntoDeDados(dataSet);
vetorDeConjuntoDeDados = vectorDataSet(conjuntoDeDado, dataSet);
mapa=finalDataSet(conjuntoDeDado,dataSet);
system("pause");
return 0;
1> Compiling CUDA source file main.cu…
1>
1> C:\Users\Giovanni\documents\visual studio 2012\Projects\eliminandoExtern\eliminandoExtern>“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.0\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" --use-local-env --cl-version 2012 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.0\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.0\include" -G --keep-dir Debug -maxrregcount=0 --machine 32 --compile -cudart static -g -DWIN32 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Zi /RTC1 /MDd " -o Debug\main.cu.obj “C:\Users\Giovanni\Documents\Visual Studio 2012\Projects\eliminandoExtern\eliminandoExtern\main.cu”
1> main.cu
1>main.cu.obj : error LNK2019: símbolo externo indefinido “class std::map<class std::basic_string<char,struct std::char_traits,class std::allocator >,class std::vector<struct vetorCRelacaoAClasse,class std::allocator >,struct std::less<class std::basic_string<char,struct std::char_traits,class std::allocator > >,class std::allocator<struct std::pair<class std::basic_string<char,struct std::char_traits,class std::allocator > const ,class std::vector<struct vetorCRelacaoAClasse,class std::allocator > > > > __cdecl finalDataSet(class std::vector<class std::basic_string<char,struct std::char_traits,class std::allocator >,class std::allocator<class std::basic_string<char,struct std::char_traits,class std::allocator > > >,class std::vector<class std::basic_string<char,struct std::char_traits,class std::allocator >,class std::allocator<class std::basic_string<char,struct std::char_traits,class std::allocator > > >)” (?finalDataSet@@YA?AV?$map@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$vector@UvetorCRelacaoAClasse@@V?$allocator@UvetorCRelacaoAClasse@@@std@@@2@U?$less@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@2@V?$allocator@U?$pair@$$CBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$vector@UvetorCRelacaoAClasse@@V?$allocator@UvetorCRelacaoAClasse@@@std@@@2@@std@@@2@@std@@V?$vector@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$allocator@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@2@@2@0@Z) referenciado na função _main
1>C:\Users\Giovanni\documents\visual studio 2012\Projects\eliminandoExtern\Debug\eliminandoExtern.exe : fatal error LNK1120: 1 externo não resolvidos
I´m using vs2012 and CUDA 6.0, ever try all procedure cited for the microsoft in your official site:
between other cited in others sites, help-me please i´m desperate.
Note: the code is functional in c/c++, but when i´m using cuda 6.0, appears this problem. I´m desperate.
