• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 7.2.2
• Issue Type( questions, new requirements, bugs) questions
First I ran the kafka server and created a topic, and then I reported an error when I ran the command:
./deepstream-test5-app -c configs/test5_config_file_src_infer.txt -p 1
# Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file://../../../../../samples/streams/sample_1080p_h264.mp4
num-sources=2
gpu-id=0
nvbuf-memory-type=0
[source1]
enable=1
type=3
num-sources=2
gpu-id=0
nvbuf-memory-type=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
# msg-broker-conn-str=<host>;<port>;<topic>
msg-broker-conn-str=192.168.1.193;9092;myKafkaServer
topic=myKafkaServer
#Optional:
#msg-broker-config=../../deepstream-test4/cfg_kafka.txt
[sink2]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
## only SW mpeg4 is supported right now.
codec=3
sync=1
bitrate=2000000
output-file=out.mp4
source-id=0
# sink type = 6 by default creates msg converter + broker.
# To use multiple brokers use this group for converter and use
# sink type = 6 with disable-msgconv = 1
[message-converter]
enable=0
# Name of library having custom implementation.
#msg-conv-msg2p-lib=<val>
# Id of component in case only selected message to parse.
#msg-conv-comp-id=<val>
# Configure this group to enable cloud message consumer.
[message-consumer0]
enable=0
config-file=<broker config file e.g. cfg_kafka.txt>
subscribe-topic-list=<topic1>;<topic2>;<topicN>
# Use this option if message has sensor name as id instead of index (0,1,2 etc.).
#sensor-list-file=dstest5_msgconv_sample_config.txt
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
[primary-gie]
enable=1
gpu-id=0
batch-size=4
## 0=FP32, 1=INT8, 2=FP16 mode
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;1;1;1
bbox-border-color3=0;1;0;1
nvbuf-memory-type=0
interval=0
gie-unique-id=1
model-engine-file=../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
labelfile-path=../../../../../samples/models/Primary_Detector/labels.txt
config-file=../../../../../samples/configs/deepstream-app/config_infer_primary.txt
#infer-raw-output-dir=../../../../../samples/primary_detector_raw_output/
[tracker]
enable=1
# For NvDCF and DeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_IOU.yml
ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_DeepSORT.yml
gpu-id=0
enable-batch-process=1
enable-past-frame=1
display-tracking-id=1
[tests]
file-loop=0
Error infomation:
1check point 1
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Initialized
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine open error
0:00:01.724404236 22410 0x5585527e00 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed
0:00:01.724544630 22410 0x5585527e00 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed, try rebuild
0:00:01.724585432 22410 0x5585527e00 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: TensorRT was linked against cuDNN 8.2.1 but loaded cuDNN 8.0.2
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine opened error
0:00:35.651055136 22410 0x5585527e00 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1942> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:35.677923633 22410 0x5585527e00 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/configs/deepstream-app/config_infer_primary.txt sucessfully
** ERROR: <main:1472>: Could not open X Display
Quitting
[NvMultiObjectTracker] De-initialized
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
App run failed
how can I solve this problem?
