So I know you cannot reference textures across files in cuda without an “invalid texture reference”.
I got my application running perfectly on the development machine (vista + quadro fx 1700)
then out of the blue, running it on a vista laptop with a geforce 9650mGT gives me an “invalid texture reference” when I bind my texture.
what the hell?
I copied all the dependency dll’s to the other machine, whats going on.
If cuda is this unreliable across machines, its commercial viability will be garbage
wait a second. Do you need to download this “cuda driver” thing on all machines you want to run the app on? If so I think that’s a little ridiculous, why wouldn’t cuda come with the display driver?
Why would the CUDA compiler package include the display driver? So yes, you do. You need a version at least as new as the associated CUDA compiler/toolkit version–180.xx or later if you’re using 2.1, 185.xx or later if you’re using 2.1, 177.xx or later if you’re using 2.0…
