I have a weird behavior with my CUDA program.
Running my program in debug mode is all fine.
Running my program in release mode crashes with a invalid texture reference error.
The problem occures at cudaBindTextureToArray:
bool BindTextureToArray(void*image, unsigned int width, unsigned int height, int imageNumber)
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc<uchar4>();
cudaMallocArray ( &ImageArray[imageNumber], &channelDesc, width, height );
cudaMemcpyToArray( ImageArray[imageNumber], 0, 0, image, sizeof(unsigned char)* width * height * 4, cudaMemcpyHostToDevice));
cudaBindTextureToArray(image0, ImageArray[imageNumber], channelDesc);
if(checkCUDAError("BindTextureToArray: cudaBindTextureToArray\n") == false)
return false;
return true;
cudaArray* ImageArray[NumberOfImages];
void* image points to a unsigned char pointer on the data
I can not image why this happens only in release mode.
Could it be because I split my code in several files?
texture global declare in: gpu_global.h
texture defined in: gpu_init.cu
BindTextureToArray in: gpu.cu
But i tried to push all my code in one file, but nothing changed.
Should i change to another Cuda Version? 2.0 or 2.2?
Or another driver version?
I would appreciate any advice, hints, thoughts…
thanks!
Hendrik
My computer configuration:
Quadro FX 3600M (notebook graphic card)
DirectX Version: 10
Driver Version: 185.85
compute capability: 1.1
Cuda compilation tools, release 2.1, V0.2.1221
