Device: Xavier NX
6 Core CPU
Operating System Ubuntu 18.04
Riva Version 2.0.0
TLT Version (if relevant)
How to reproduce the issue ? I setup Riva 2.0 and every thing run well. When i send request to riva server for Transcribe give me Error: Model is not available on server.
How can i solve this issue?
Hi @Mr.razzaghi
Thanks for your interest in Riva
Apologies you are facing error,
It would be kind if you share the config.sh
used in case you followed riva quickstart or the complete riva-build
command in case you used a custom model
Please do share the output of docker logs riva-speech
I would also appreciate to know
- which model you are interested in using, and the audio file you are trying to transcribe (if possible)
- The Output of complete error log which occurs when sending request for transribe to riva server
config.sh (10.3 KB)
Uploading: riva-speech.log…
I just got this error without more details: Model is not available on server
For now I want to test all available models to evaluate them accuracy.
riva-speech.log (57.8 KB)
log attached in this post
