Hello all
I am trying to use a library written in CUDA in my own C++ program. As I call the functions of this library, I get the following errors -
Error: no kernel image is available for execution on the device
Error: driver shutting down
After searching a lot on the internet, I realized this error is due to unmatched compute capability settings in the library’s CMakeLists.txt. Hence I modified the library’s CMakeLists.txt as shown below. But nothing seemed to change after building with the changes. My code still gives me the same error. I have also attached the result of running - nvidia-smi to give more information about my system. Is the driver being 384.13 a problem for using cuda 9.0? Should I update my driver? Please let me know the steps if so.
System specs -
intel i5 7th gen
8GB RAM
2GB GeForce 940MX GPU
installed CUDA 9.0
CMakeLists.txt
cmake_minimum_required(VERSION 2.8.3)
project(ndt_gpu)
find_package(PCL REQUIRED)
find_package(CUDA)
find_package(autoware_build_flags PATHS /home/amey/NDT_GPU_Autoware/autoware-623c51c8dc29f2d9d66ed6cbd39bcfb1d45183b7-ros-src-computing-perception-localization-lib-ndt_gpu/ros/src/computing/perception/localization/lib/ndt_gpu/autoware_build_flags/cmake/catkin_generated/installspace NO_DEFAULT_PATH)
find_package(Eigen3 QUIET)
if (NOT EIGEN3_FOUND)
# Fallback to cmake_modules
find_package(cmake_modules REQUIRED)
find_package(Eigen REQUIRED)
set(EIGEN3_INCLUDE_DIRS ${EIGEN_INCLUDE_DIRS})
set(EIGEN3_LIBRARIES ${EIGEN_LIBRARIES}) # Not strictly necessary as Eigen is head only
# Possibly map additional variables to the EIGEN3_ prefix.
else ()
set(EIGEN3_INCLUDE_DIRS ${EIGEN3_INCLUDE_DIR})
endif ()
AW_CHECK_CUDA()
if (USE_CUDA)
set_directory_properties(PROPERTIES COMPILE_DEFINITIONS "")
message("CUDA_ARCH is: " ${CUDA_ARCH})
if(CMAKE_CROSSCOMPILING)
if(NOT CUDA_ARCH)
message(FATAL_ERROR "Please define the CUDA_ARCH CMake variable")
endif()
else()
if (NOT DEFINED CUDA_CAPABILITY_VERSION_CHECKER)
set(CUDA_CAPABILITY_VERSION_CHECKER
"${CATKIN_DEVEL_PREFIX}/lib/capability_version_checker")
endif ()
execute_process(COMMAND ${CUDA_CAPABILITY_VERSION_CHECKER}
OUTPUT_VARIABLE CUDA_CAPABILITY_VERSION
OUTPUT_STRIP_TRAILING_WHITESPACE)
if ("${CUDA_CAPABILITY_VERSION}" MATCHES "^[1-9][0-9]+$")
set(CUDA_ARCH "sm_${CUDA_CAPABILITY_VERSION}")
else ()
set(CUDA_ARCH "sm_52")
set(CUDA_CAPABILITY_VERSION "52")
endif ()
endif()
#set(CUDA_NVCC_FLAGS ${CUDA_NVCC_FLAGS};-arch=${CUDA_ARCH};-std=c++11;--ptxas-options=-v)
set(
CUDA_NVCC_FLAGS
${CUDA_NVCC_FLAGS};
-O3
-gencode arch=compute_30,code=sm_30
-gencode arch=compute_35,code=sm_35
-gencode arch=compute_50,code=[sm_50,compute_50]
-gencode arch=compute_52,code=[sm_52,compute_52]
#-gencode arch=compute_61,code=sm_61
#-gencode arch=compute_62,code=sm_62
-std=c++11
--ptxas-options=-v
message("ARCH is: " ${arch})
#string(APPEND CUDA_NVCC_FLAGS " -gencode arch=compute_52,code=sm_52")
link_directories(/usr/local/cuda-9.0/lib64)
set(SUBSYS_DESC "Point cloud ndt gpu library")
message("CUDA ARCHITECTURE: " ${CUDA_ARCH})
message("CUDA CAPABILITY: " ${CUDA_CAPABILITY_VERSION})
message("CUDA_NVCC_FLAGS: " ${CUDA_NVCC_FLAGS})
catkin_package(
DEPENDS PCL #Non-catkin CMake projects
INCLUDE_DIRS include #The exported include paths
LIBRARIES ndt_gpu #The exported libraries from the project
include_directories(
${PCL_INCLUDE_DIRS}
${catkin_INCLUDE_DIRS}
${CUDA_INCLUDE_DIRS}
include
${EIGEN3_INCLUDE_DIRS}
set(srcs
src/MatrixDevice.cu
src/MatrixHost.cu
src/NormalDistributionsTransform.cu
src/Registration.cu
src/VoxelGrid.cu
src/SymmetricEigenSolver.cu
set(incs
include/ndt_gpu/common.h
include/ndt_gpu/debug.h
include/ndt_gpu/Matrix.h
include/ndt_gpu/MatrixDevice.h
include/ndt_gpu/MatrixHost.h
include/ndt_gpu/NormalDistributionsTransform.h
include/ndt_gpu/Registration.h
include/ndt_gpu/SymmetricEigenSolver.h
include/ndt_gpu/VoxelGrid.h
cuda_add_library(ndt_gpu ${srcs} ${incs})
target_link_libraries(ndt_gpu
cuda
${CUDA_LIBRARIES}
${CUDA_CUBLAS_LIBRARIES}
${CUDA_curand_LIBRARY}
${PCL_LIBRARIES}
install(DIRECTORY include/${PROJECT_NAME}/
DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
FILES_MATCHING PATTERN "*.h"
install(TARGETS ndt_gpu
ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
else ()
message("ndt_gpu will not be built, CUDA was not found.")
endif ()
Result of nvidia-smi
Tue Oct 15 21:20:16 2019
| NVIDIA-SMI 384.130 Driver Version: 384.130 |
| 0 GeForce 940MX Off | 00000000:01:00.0 Off | N/A |
| N/A 40C P8 N/A / N/A | 296MiB / 2002MiB | 19% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1635 G /usr/lib/xorg/Xorg 182MiB |
| 0 4444 G compiz 43MiB |
| 0 5453 G ...quest-channel-token=4287617565245160848 13MiB |
| 0 7128 G ...quest-channel-token=5767221912348951501 52MiB |
| 0 9002 G /usr/lib/firefox/firefox 1MiB |
| 0 13185 G /usr/lib/firefox/firefox 1MiB |
