addKernel launch failed: no kernel image is available for execution on the device
I loaded a CUDA template from Visual Studio 2022, compiled it (with a warning about conflicting libraries), and ran the “Start without debug.” The console comes up and displays
addWithCuda failed!
I see this has been brought up on the forum quite a few times, and the suggestion was to compile with nvcc and run it from that as a solution. So I did.
nvcc -ccbin "C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.39.33519\bin\Hostx64\x64\cl.exe" -arch=sm_52 -o kernel1000.exe kernel.cu
For some odd reason, cl.exe just refuses to appear in the path depsite be putting it in the system, and account path so I had to force it.
During compile time on the command line it displayed the following:
tmpxft_0000072c_00000000-10_kernel.cudafe1.cpp
   Creating library kernel1000.lib and object kernel1000.exp
Upon execution of the compile binary, i get the same result.
This is on my intel based laptop with a 940MX.
And here is nvidia-smi
Wed Feb 21 12:41:52 2024
| NVIDIA-SMI 546.17 Driver Version: 546.17 CUDA Version: 12.3 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce 940MX WDDM | 00000000:01:00.0 Off | N/A |
| N/A 0C P8 N/A / 200W | 0MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Any clues on resolving this?
940MX is a compute capability 5.0 GPU. You need to compile for a architecture that matches your GPU. CUDA 11.x and 12.x compile by default for cc5.2. See here.
Thank you for helping me understand this. The installation of the SDK had put “compute_52,sm_52” into Visual Studio and I had assumed that was correct.
