• Hardware Platform (Jetson / GPU) AGX ORIN • DeepStream Version6.2
I’m trying to read the FPS across 4 input sources. However it shows the below error"
File “/home/orin/Desktop/DeepStream/pipeline2.py”, line 195, in sgie_sink_pad_buffer_probe
perf_data.update_fps(stream_index)
File “/home/orin/Desktop/DeepStream/sources/deepstream_python_apps/apps/Multi/common/FPS.py”, line 67, in update_fps
self.all_stream_fps[stream_index].update_fps()
KeyError: ‘stream2’
running 2 input sources work well even with 4 input sources. This issue only raised when calculating the FPS. FPS can measure with 2 input sources “stream0” “stream1” however it doesn’t measure more than these 2 so it shows an error in stream2
