Multiple RTSP sources with different FPS
Hello to all,
I am using a deepstream pipeline (using python) connecting to multiple RTSP sources, everything works like a charm once the sources have the same FPS, but once the FPS is changed, the higher fps cameras begin to drop.
How can I fix that issue? I have worked with several parameters like “sync-inputs”, “batched-push-timeout” and more but didn’t find any solution (yet).
Tried to add videorate element , no success
Hardware: XAVIER AGX
SDK : Deepstram 6.0
Has anyone experienced this problem?
I would greatly appreciate the help.
Thank you
Hi, there
I see that no one is answering so i will write my solution, which maybe one day help somebody (or not ) , anyway, i have added a “videorate” element to the existing pipeline (after uridocebin and before streamux ), this way, i have ensure that all sources will work with same fps and no source will drop frames or create delay
Best
