• Hardware Platform (Jetson / GPU) Xavier nx / T1000
• DeepStream Version 5.0/5.1
• JetPack Version (valid for Jetson only) 4.4/4.5
• TensorRT Version 7.1/7.2
• NVIDIA GPU Driver Version (valid for GPU only) 455/460
• Issue Type( questions, new requirements, bugs) RTSPStreaming output delay and blurred
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) The RTSP source is 25 FPS, but deepstream sink rtspstreaming is 30FPS, that leads to output stream delay and blurred screen,
Now I alleviate the phenomenon of blurred screen by configuring the sink component iframeinternal = 25, but there is still the phenomenon of stuck, the RTSP source is 25 FPS, but deepstream sink rtspstreaming is 30FPS, How to Set Deepstream RTSPStreaming output FPS?
In GStreamer, the FPS of the output stream can be set through the framerate property. How to keep FPS of output stream consistent with that of input stream in deepstream?
The partial configuration
[sink11]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=1
iframeinterval=25
#bitrate=4000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=2
#set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
source-id=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
##Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
##If set to TRUE, system timestamp will be attached as ntp timestamp
##If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
attach-sys-ts-as-ntp=1
