Different multi rtsp dealy,but same is real time
I created a link
uricodebin streammux pgie tiler nvvidconv nvosd nvvidconv_postosd caps encoder rtppay sink
thats is test3 add rtsp-out
if i input the same rtsp stream ,the fps is 25
but i input differenet ,the fps is 16,the stream will delay
Why is that?
Have you modified deepstream-test3? How do you measure FPS with deepstream-test3? Do you know the original frame rate of each rtsp source you used?
Yes I add test1-rtsp-out
Use Common.FPS import GETFPS
25fps
Can you provide your python script?
My python script
a.py (15.0 KB)
thats out
FPS*******************
Fps of stream 0 is 16.6
Fps of stream 1 is 25.0
Can you set ‘batch-size’ of nvstreammux to number_sources? Please change ‘sink.set_property(‘sync’, 1)’ to ‘sink.set_property(‘sync’, 0)’
ok, i will change it, and report .
btw,the udpsink not has ‘sync’ in this web, Can you provide some information?
this web : udpsink
‘sync’ is from GstBaseSink https://gstreamer.freedesktop.org/documentation/base/gstbasesink.html?gi-language=c, most sinks are derived from it.
