Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.0.1
• TensorRT Version 7.0.11
• NVIDIA GPU Driver Version (valid for GPU only) 460.32.03
• Issue Type( questions, new requirements, bugs) question
In case the input RTSP’s fps is greater than the deepstream binary’s fps, then I’m observing jitter for fast-moving objects in the frame as in the below images.
I’m using deepstream-app, this issue is encountered in both
- the original input frames that I extract from deepstream in probe function
- the output video that is saved
If I decrease the fps of input RTSP s.t. it’s less than deepstream fps, this issue doesn’t arise.
