• DeepStream Version 6.0
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 450.0
I’ve tried this solution and it worked perfectly.
“For RTSP streaming input, if the input has high jitter the GStreamer rtpjitterbuffer
element might drop packets which are late. Increase the latency property of rtspsrc
, for deepstream-app
set latency
in [source*] group. Alternatively, if using RTSP type source (type=4) with deepstream-app
, turn off drop-on-latency
in deepstream_source_bin.c
. These steps may add cumulative delay in frames reaching the renderer and memory accumulation in the rtpjitterbuffer
if the pipeline is not fast enough”
However, by the time, the delay for the streaming continue to increasing.
How can we reduce the overall delay or release the buffer in order to address the jitter problem with an RTSP stream?
