RTSP glitch in deepstream app
**• Hardware Platform = Jetson **
• DeepStream Version = 5.1
• JetPack Version = 4.5.1
• TensorRT Version = 7.1.3
• Issue Type = question and bug
Hi. I’m working with RTSP streams in deepstream-app or deepstream-test5-app and I’m getting glitches in the RTSP stream. I have followed the guidelines and also followed some forums which suggested the following.
  1. Streammux and primary-gie batch size should be same as that of the number of RTSP sources. I tried this but still I’m getting the glitches.
  2. I enabled the NVDS_ENABLE_LATENCY_MEASUREMENT and found the latency of the stream. I added that latency in the [sourcex] group as i have a property named as latency. This also failed.
I also tried by increasing and decreasing the batch size for streammux and primary-gie but it didn’t helped me.
How can i avoid the glitching of RTSP stream in the deepstream application?
Please try this:
deepstream4.0 with rtsp of sink makes the picture distortion with high bitrate - #9 by DaneLLL
And may try to disable primary-gie to check if the issue happens without running deep learning inferences.
