Neeed clarity for batch-size and batched-push-timeout for rtsp source
• Hardware Platform (Jetson / GPU) GPU (1080ti)
• DeepStream Version 5.0
• TensorRT Version 7.2.1
• NVIDIA GPU Driver Version (valid for GPU only) 450.102.04
• Issue Type( questions, new requirements, bugs) Question
I want to know few things (specially for RTSP source)-
  1. If i want to use 10 rtsp cameras with 20 fps , 1080p, 4096 constant bitrate, h264 decoder so what should be my batch-size and batched-push-timeout values?
As in this post (“DS 5.0.1 nvstreammux batch-size bug? - #12 by Fiona.Chen”), i can see max batch-size i can set is 4 due to HW decoder limitation. But it is generally recommended that to use batch-size same as number of sources.
  1. If i set it 4, then output gets delayed and memory is constantly goes to increase (in around 3-4 hrs) like it shows sync behaviour. And when i set it to 10, output is realtime but glitchy images starts appear.
  1. Batch size of nvstreammux should be the same to stream number. For 10 streams, nvstreammux batch size should be 10 too. The post DS 5.0.1 nvstreammux batch-size bug? - #12 by Fiona.Chen wants to set nvstreammux batch size larger than stream number, this is not recommended. batched-push-timeout can be calculated by 1000000(us)/FPS = 50000
  2. Batch size of nvstreammux should be the same to stream number. Frequently Asked Questions — DeepStream 6.1.1 Release documentation
One more thing is does bitrate from rtsp camera affects the decoder performance?
Like if i set it 1024, then 6 cameras runs fine, if i set it to 4096, then glitch appears.
Also what should be the ideal iframeinterval for 20fps?
Note-
Network Bandwidth is not the bottleneck.
The high bitrate will cause more network delay, deepstream is only a rtsp client. You can monitor the GPU loading to check whether video decoder is the bottleneck when you run your case.
ok thanks for the support
