• Hardware Platform (Jetson / GPU): Jetson • DeepStream Version: 5.0 • JetPack Version (valid for Jetson only): 4.6 • TensorRT Version: 7.1.3 • NVIDIA GPU Driver Version (valid for GPU only)
I have a question regarding property “batched-push-timeout” in nvstreammux after reading this post NVSTREAMMUX batched-push-timeout value/calculation
It looks like “batched-push-timeout” should be set according to fps from the source.
Our UDP sources stream 30 fps videos but nvinfer is inferencing half of the frames (''interval=1"). Our fastest frame processing is around 4 ms(the frame without inference) and the worst one is around 110 ms (the frame with inference).
Our current “batched-push-timeout” is set as 25000 microsecs and I see a lot of frames in batches are missing. But given half of the frames are efficient enough within 10 ms due to “interval = 1”, do I need to increase the 25000 or not?
Thanks. In my case, since interval = 1 setting from nvinfer(i.e. half of the frames are passing the inference engine), does it affect setting the value of batched-push-timeout=1/max_fps? Shall I consider the max_fps as 15 fps and set batched-push-timeout to 66666 microsecs?
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks
