• Hardware Platform (Jetson / GPU) NVIDIA A2 • DeepStream Version 6.3 • TensorRT Version 8.4.0 • NVIDIA GPU Driver Version (valid for GPU only) 535.129.03
I am using a Deepstream pipeline in Python and inferring it with nvinfersever with rtsp streams of 60 fps.
Now, I am trying to calculate batched-push-timeout property in streammux. I could find more than one way to calculate it. Some people say 1/max_fps and others say 1000000/max_fps I think they are the same somehow. Well, the problem is when I use these values, some of the frames get processed and the others are delayed. for example, some cameras process on frame #10, and two or three cameras are delayed processing on frame #7.
This causes issues in our tracker service since we are doing multi-cam tracking, so clustering objects isn’t working correctly.
When I remove that property if a stream gets down or something, my whole pipeline hangs, maybe it waits for the full batch. So, how can I set it correctly?
Note: I am using 30 streams. If it makes any difference in calculating the value of it.
From your description, seems your cameras are not aligned. Have you checked that the timestamps of the frames? Are the timestamp aligned between the cameras?
Okay, I am not sure if it matters that I get the timestamps before or after nvstreammux. But, I could get the ntp_timestamp in NvDsFrameMeta from pgie probe function (same as deepstream_test_3). And the batched_push_timeout is set to 20000 since my sources are 60 fps. And here’s a snapshot from the output:
Okay, I get it!
As I understand, if there are 32 sources, nvstreammux tries to form a batch of 32 frames. Is it correct?
If it is set to 20000 for example (since fps is 60) and also, I assume 20ms is enough to form a batch as described. As you can see in the screenshot the batch has different frames which isn’t logical. I assume the whole batch should have the same frame ID.
Okaaaayyyy. So let’s assume we have a frame with timestamp X it should be batched with all frames with timestamps between [X - batched_push_timeout, X] inclusive.
If it’s current, let me know how to check the timestamps before nvstreammux to reproduce it in my python code.
You are using gst-python bindings to write python pipeline, it is just a normal GStreamer pipeline. I’ve mentioned “There is timestamp in GstBuffer. Please write code to read them.”
