Value of batched-push-timeout for NVSTREAMMUX with multiple inputs of different fps
**• Hardware Platform (Jetson / GPU)Jetson Orin Nano
**• DeepStream Version6.3
• JetPack Version (valid for Jetson only) 5.1.2
• TensorRT Version
I would like to determine the value of batched-push-timeout in NVSTREAMMUX.
I am referring to https://forums.developer.nvidia.com/t/nvstreammux-batched-push-timeout-value-calculation/154073.
  • 12fps source: 1 / 12 * 1000 * 1000 = 83333 (microseconds)
  • 25fps source: 1 / 25 * 1000 * 1000 = 40000 (microseconds)
  • 30fps source: 1 / 30 * 1000 * 1000 = 33333 (microseconds)
For example, if there is only one input, the calculation is as above,
What is the calculation for two or more inputs and different fps?
For example, 25fps and 30fps.
You can refer to our FAQ first.
Is it correct to calculate the value according to the maximum fps?
If you want to get high fps, set the batched-push-timeout according to the maximum fps.
I understand. Thank you very much.
