Dropping the FPS of input rtsp streams
GPU: A100
CUDA Version: 12.6
• DeepStream Version: 7.0
• TensorRT Version: 10.7.0.23-1+cuda12.6
• NVIDIA GPU Driver Version (valid for GPU only): 560.35.05
• Issue Type: questions
I am trying to reduce the FPS of incoming RTSP streams to my deepstream pipeline. I am using Gst-nvstreammux-new. I tried to set properties like overall-max-fps-n=8, overall-max-fps-d=1, sync-inputs=1. But still the FPS is not decreased. I think I am missing out something here as I am new to this framework.
The actual FPS are between 15 and I want to reduce it to 5.
I have attached the main code of building the pipeline.
def main(args, requested_pgie=None, config=None, disable_probe=False, op_ports=[554]):
    global perf_data
    perf_data = PERF_DATA(len(args))
    number_sources=len(args)
    platform_info = PlatformInfo()
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ",i," \n ")
        uri_name=args[i]
        if uri_name.find("rtsp://") == 0 :
            is_live = True
        source_bin=create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname="sink_%u" %i
        sinkpad= streammux.request_pad_simple(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad=source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    queue1=Gst.ElementFactory.make("queue","queue1")
    queue2=Gst.ElementFactory.make("queue","queue2")
    queue3=Gst.ElementFactory.make("queue","queue3")
    queue4=Gst.ElementFactory.make("queue","queue4")
    queue5=Gst.ElementFactory.make("queue","queue5")
    queue6=Gst.ElementFactory.make("queue","queue6")
    pipeline.add(queue1)
    pipeline.add(queue2)
    pipeline.add(queue3)
    pipeline.add(queue4)
    pipeline.add(queue5)
    pipeline.add(queue6)
    nvdslogger = None
    print("Creating Pgie \n ")
    if requested_pgie != None and (requested_pgie == 'nvinferserver' or requested_pgie == 'nvinferserver-grpc') :
        pgie = Gst.ElementFactory.make("nvinferserver", "primary-inference")
    elif requested_pgie != None and requested_pgie == 'nvinfer':
        pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    else:
    if not pgie:
        sys.stderr.write(" Unable to create pgie :  %s\n" % requested_pgie)
    if disable_probe:
        # Use nvdslogger for perf measurement instead of probe function
        print ("Creating nvdslogger \n")
        nvdslogger = Gst.ElementFactory.make("nvdslogger", "nvdslogger")
    print("Creating tracker \n ")
    tracker = Gst.ElementFactory.make("nvtracker", "object-tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    tracker.set_property("tracker-width", 640)
    tracker.set_property("tracker-height", 384)
    tracker.set_property("gpu-id", 0)
    tracker.set_property("ll-lib-file", "../../../../lib/libnvds_nvmultiobjecttracker.so")
    tracker.set_property("ll-config-file", "../../../../samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml")
    tracker.set_property("compute-hw", 1)
    tracker.set_property("display-tracking-id", 1)
    print("Creating tiler \n ")
    tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write(" Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    nvosd.set_property('process-mode',OSD_PROCESS_MODE)
    nvosd.set_property('display-text',OSD_DISPLAY_TEXT)
    if file_loop:
        if platform_info.is_integrated_gpu():
            pass
            # Set nvbuf-memory-type=4 for integrated gpu for file-loop (nvurisrcbin case)
            # streammux.set_property('nvbuf-memory-type', 4)
        else:
            pass
            # Set nvbuf-memory-type=2 for x86 for file-loop (nvurisrcbin case)
            # streammux.set_property('nvbuf-memory-type', 2)
    if no_display:
        print("Creating Fakesink \n")
        sink = Gst.ElementFactory.make("fakesink", "fakesink")
        sink.set_property('enable-last-sample', 0)
        sink.set_property('sync', 0)
    else:
        sink = Gst.ElementFactory.make("nvrtspoutsinkbin", "nvrtspoutsinkbin")
        sink.set_property('codec','h264')
        sink.set_property('enc-type',1)
        sink.set_property('rtsp-mount-point',f"/{STREAM_IDS[0]}")
        sink.set_property('rtsp-port', int(op_ports[0]))
        sink.set_property('bitrate',4000000)
    if not sink:
        sys.stderr.write(" Unable to create sink element \n")
    if is_live:
        print("At least one of the sources is live")
#        streammux.set_property('live-source', 1)
    # streammux.set_property('width', 1920)
    # streammux.set_property('height', 1080)
    streammux.set_property('batch-size', number_sources)
    streammux.set_property('batched-push-timeout', MUXER_BATCH_TIMEOUT_USEC)
    streammux.set_property('config-file-path', 'nvstreamux_fps.txt')
    if requested_pgie == "nvinferserver" and config != None:
        pgie.set_property('config-file-path', config)
    elif requested_pgie == "nvinferserver-grpc" and config != None:
    elif requested_pgie == "nvinfer" and config != None:
    else:
        pgie.set_property('config-file-path', "dstest3_pgie_config.txt")
    pgie_batch_size=pgie.get_property("batch-size")
    if pgie_batch_size != number_sources:
        print("WARNING: Overriding infer-config batch-size",pgie_batch_size," with number of sources ", number_sources," \n")
        pgie.set_property("batch-size",number_sources)
    # pgie.set_property("operate-on-class-ids", f"{PGIE_CLASS_ID_PERSON}")
    pgie.set_property("filter-out-class-ids", f"1,2,3")
    tiler_rows=int(math.sqrt(number_sources))
    tiler_columns=int(math.ceil((1.0*number_sources)/tiler_rows))
    tiler.set_property("rows",tiler_rows)
    tiler.set_property("columns",tiler_columns)
    tiler.set_property("width", TILED_OUTPUT_WIDTH)
    tiler.set_property("height", TILED_OUTPUT_HEIGHT)
        tiler.set_property("compute-hw", 2)
    else:
        tiler.set_property("compute-hw", 1)
    sink.set_property("qos",0)
    print("Adding elements to Pipeline \n")
    pipeline.add(pgie)
    pipeline.add(tracker)
    if nvdslogger:
        pipeline.add(nvdslogger)
    pipeline.add(tiler)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(sink)
    print("Linking elements in the Pipeline \n")
    streammux.link(queue1)
    queue1.link(pgie)
    pgie.link(queue2)
    queue2.link(tracker)
    tracker.link(queue3)
    if nvdslogger:
        queue3.link(nvdslogger)
        nvdslogger.link(tiler)
    else:
        queue3.link(tiler)
    tiler.link(queue4)
    queue4.link(nvvidconv)
    nvvidconv.link(queue5)
    queue5.link(nvosd)
    nvosd.link(queue6)
    queue6.link(sink)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    pgie_src_pad = pgie.get_static_pad("src")
    if not pgie_src_pad:
        sys.stderr.write(" Unable to get src pad \n")
    else:
        if not disable_probe:
            pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, pgie_src_pad_buffer_probe, 0)
            # perf callback function to print fps every 5 sec
            GLib.timeout_add(5000, perf_data.perf_print_callback)
    tracker_source_pad = tracker.get_static_pad("src")
    if not tracker_source_pad:
        sys.stderr.write(" Unable to get tracker src pad \n")
    else:
            tracker_source_pad.add_probe(Gst.PadProbeType.BUFFER, tracker_probe)
    nvosd_sink_pad = nvosd.get_static_pad("sink")
    if not nvosd_sink_pad:
        sys.stderr.write(" Unable to get sink pad \n")
    else:
            nvosd_sink_pad.add_probe(Gst.PadProbeType.BUFFER, nvosd_sink_pad_buffer_probe, None)
    # Enable latency measurement via probe if environment variable NVDS_ENABLE_LATENCY_MEASUREMENT=1 is set.
    # To enable component level latency measurement, please set environment variable
    # NVDS_ENABLE_COMPONENT_LATENCY_MEASUREMENT=1 in addition to the above.
    if environ.get('NVDS_ENABLE_LATENCY_MEASUREMENT') == '1':
        print ("Pipeline Latency Measurement enabled!\nPlease set env var NVDS_ENABLE_COMPONENT_LATENCY_MEASUREMENT=1 for Component Latency Measurement")
        global measure_latency
        measure_latency = True
    # List the sources
    print("Now playing...")
    for i, source in enumerate(args):
        print(i, ": ", source)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    # cleanup
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
The new nvstreammux will only change the output FPS but not input FPS. If you only want to change the input RTSP FPS, please do it in the RTSP server but not in DeepStream pipeline, the DeepStream pipeline is just a client.
