Error starting nvgstcapture-1.0 on JETSON NANO 4GB(B01/SUB)
There was a problem starting nvgstcapture-1.0. Error following
nano@nano-desktop:~$ nvgstcapture-1.0
Encoder null, cannot set bitrate!
Encoder Profile = High
Supported resolutions in case of ARGUS Camera
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Runtime ARGUS Camera Commands:
Help : ‘h’
Quit : ‘q’
Set Capture Mode:
mo:
(1): image
(2): video
Get Capture Mode:
gmo
Set sensor orientation:
so:
(0): none
(1): Rotate counter-clockwise 90 degrees
(2): Rotate 180 degrees
(3): Rotate clockwise 90 degrees
Get sensor orientation:
gso
Set sensor mode:
smo: e.g., smo:1
Get sensor mode:
gsmo
Set Whitebalance Mode:
wb:
(0): off
(1): auto
(2): incandescent
(3): fluorescent
(4): warm-fluorescent
(5): daylight
(6): cloudy-daylight
(7): twilight
(8): shade
(9): manual
Get Whitebalance Mode:
gwb
Set Saturation (0 to 2):
st: e.g., st:1.25
Get Saturation:
gst
Set Exposure Compensation (-2 to 2):
ec: e.g., ec:-2
Get Exposure Compensation:
gec
Set Auto Whitebalance Lock:
awbl: e.g., awbl:0
Get Auto Whitebalance Lock:
awbl
Set Auto Exposure Lock:
ael: e.g., ael:0
Get Auto Exposure Lock:
gael
Set TNR Mode:
tnrm: e.g., tnrm:1
(0): OFF
(1): FAST
(2): HIGH QUALITY
Get TNR Mode:
gtnrm
Set TNR Strength (-1 to 1):
tnrs: e.g., tnrs:0.5
Get TNR Strength:
gtnrs
Set EE Mode:
eem: e.g., eem:1
(0): OFF
(1): FAST
(2): HIGH QUALITY
Get EE Mode:
geem
Set EE Strength (-1 to 1):
ees: e.g., ees:0.5
Get EE Strength:
gees
Set Auto Exposure Anti-Banding (0 to 3):
aeab: e.g., aeab:2
(0): OFF
(1): MODE AUTO
(2): MODE 50HZ
(3): MODE 60HZ
Get Auto Exposure Anti-Banding:
gaeab
Set Gain Range:
gr: e.g., gr:1 16
Get Gain Range:
ggr
Set Exposure Time Range:
etr: e.g., etr:34000 35000
Get Exposure Time Range:
getr
Set ISP Digital Gain Range:
dgr: e.g., dgr:2 152
Get ISP Digital Gain Range:
gdgr
Capture: enter ‘j’ OR
followed by a timer (e.g., jx5000, capture after 5 seconds) OR
followed by multishot count (e.g., j:6, capture 6 images)
timer/multihot values are optional, capture defaults to single shot with timer=0s
Start Recording : enter ‘1’
Stop Recording : enter ‘0’
Video snapshot : enter ‘2’ (While recording video)
Get Preview Resolution:
gpcr
Get Image Capture Resolution:
gicr
Get Video Capture Resolution:
gvcr
Runtime encoder configuration options:
Set Encoding Bit-rate(in bytes):
br: e.g., br:4000000
Get Encoding Bit-rate(in bytes):
gbr
Set Encoding Profile(only for H.264):
ep: e.g., ep:1
(0): Baseline
(1): Main
(2): High
Get Encoding Profile(only for H.264):
gep
Force IDR Frame on video Encoder(only for H.264):
Enter ‘f’
** (nvgstcapture-1.0:10452): ERROR **: 17:46:35.044: <create_csi_cap_bin:2187> Element nvarguscamerasrc creation failed
Ловушка трассировки/останова (стек памяти сброшен на диск)
Please help me solve the problem!
Please share which camera you are using. Probably the sensor driver is not ready.
And please share your release version:
$ head -1 /etc/nv_tegra_release
Thanks for the answer. I am using an IMX219 camera.
R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t210ref, EABI: aarch64, DATE: Fri Oct 16 19:44:43 UTC 2020
Do you mean you use Raspberry Pi camera v2?
Yes!
Checked Gstreamer blacklist information. Could this be related?
$ gst-inspect-1.0 -b
Blacklisted files::
libgstnvarguscamerasrc.so
libgstnvvideocuda.so
Total number: 2 blacklisted files
It looks like you use the camera from waveshare. May need to check with the vendor for porting driver to the release.
If the driver is ready, this gstreamer command should run well:
$ gst-launch-1.0 nvarguscamerasrc ! fakesink
Unfortunately, nothing has changed!
WARN: erroneous pipeline: element ‘nvarguscamerasrc’ not found
Thanks for your answers, you are the best! I already figured it out!
Cleared the Gstream cache and it worked!
$ rm -f ~/.cache/gstreamer-1.0/registry.aarch64.bin
