I am using apptainer (a.k.a singularity) containerization and docker bootstrap setting to pull the 22.08 version of the Triton Inference server. We currently have the 18.04 version. It starts the build and gets to the last blob and I receive the following message.
FATAL: While performing build: conveyor failed to get: initializing source oci:/root/.apptainer/cache/blob:6daea0f76f1f452ff40e58d15d49236300cda2281bafa4e48712a14649518d9b: copying system image from manifest list: writing blob: happened during read: unexpected EOF.
I downloaded the latest Rapids container and tried to build it. It got past the blobs, but errored out here:
INFO: Creating SIF file…
FATAL: While performing build: while creating squashfs: create command failed: exit status 1:
Write failed because No space left on device
We point to a another directory using symbolic links for both the previous install of Singularity and the latest for the Apptainer.
lrwxrwxrwx 1 root root 21 Aug 4 07:36 .apptainer → /data/root/.apptainer
lrwxrwxrwx 1 root root 23 Aug 4 07:38 .singularity → /data/root/.singularity
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/VGdata-LGdata 26T 1.3T 25T 6% /data
I have also tried to pull the Triton Inference Server container to another server with the same result.
